Home > Technical (L322) > Any tips on replacing coolant water pump
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Well tonight I took the electrical connector off the bottom of my chargecooler pump - and guess what - my wiring was wrong as well.
So I swapped the wires in the connector and plugged it all back in - The TSB says the pump will need replaced but I'm going to leave it and see how it goes.....can't imagine that much damage being done to it.
Post #63342 10th May 2011 8:55pm
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I would say all supercharge owners should check. I'm surprised LR don't acknowledge this as a bigger problem than it is. I was also surprised that the indy was going to use completely ignored it and claimed it was a fueling problem. Apparently the pump can run backwards for a long time and may never actually fail or throw any codes up so maybe no damage has been done. At least its a straight forward job to replace.
Cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #63347 10th May 2011 9:57pm
