Home > My Range Rover > Back with another Supercharged
Page 27 of 58 <123 ... 262728 ... 565758>
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Hi David
Just watched the SC strip down video.
Great to watch a excellent presentation for a first attempt Thumbs Up Thumbs Up
Have to get a press - so useful
Douglas 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #630803 6th May 2022 4:47pm
dhallworth
I wasn’t going to publicise that Laughing
I was coerced into doing it. Still keep thinking of taking it down as I really don’t like the sound of my own voice and wish I’d tidied the work bench more before doing it.
Am just about ready to reassemble now but am tempted not to video it as I don’t want proof of a cock up if anything goes wrong!
Supercharger back from vapour blasting today.
Promptly stuck in the dishwasher to make sure there’s no media left anywhere near it!
Can you tell Mrs H is out tonight?
A little present from Powerhouse also arrived today.
I was going to go for the 10% but couldn’t be bothered with the hassle of machining the snout and after reading the link Sandy posted decided the 6% would be sufficient.
Post #630808 6th May 2022 5:23pm
Wow
Those cases look like new Bow down Bow down 2007 4.2SC Buckingham Blue
Post #630838 6th May 2022 9:42pm
And you should continue the videos
Your voice is completely fine. I do a lot of training videos and think I sound awful. Everyone else says they’re great. It’s the knowledge imparted that’s important.
Won’t disagree about the state of the bench though Rolling with laughter Rolling with laughter 2007 4.2SC Buckingham Blue
Post #630839 6th May 2022 9:44pm
How much was the pulley, if you don’t mind me asking..
I assume you need a shorter belt as well. What other changes need to be made.
You are making it all look very DIYable a specially if no remap required as Sandy suggested from memory
Post #630840 6th May 2022 9:48pm
Also, as it goes back together, can you show where the oil filler is and why it’s such a pain to fill
Thanks
Post #630841 6th May 2022 9:49pm
Danwilderspin
Has the head swap begun yet? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #630842 6th May 2022 9:50pm
And a Siemens dishwasher if I’m not mistaken Embarassed Embarassed 2007 4.2SC Buckingham Blue
Post #630843 6th May 2022 9:51pm
dhallworth
Pulley was £185 from Powerhouse Automotive. There’s a chance that it might need a small amount of material removing from the snout but nothing like the 10%.
Filling it is an awkward sod of a job just to get the plug in and out. With the engine cover off, look for the snout of the charger, then look to the right of it (passengers side of the car).
It’s much, much easier to do that then it is to remove the charger.
Everything is removed from the front of the engine. Timing cover is coming off tomorrow, then with a bit of luck the heads will be off tomorrow afternoon too.
New chains and tensioners arrived today but the slowest bit I reckon is going to be setting the valve clearances. The tappets aren’t shimmed, it’s the actual buckets you need to change so there’s going to be a lot of measuring going on and then ordering the new tappets from Duckworths.
Post #630845 6th May 2022 10:02pm
dhallworth
Haven’t a clue… my folks are away for the week so when I was putting stuff in the workshop I made use of their dishwasher. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #630846 6th May 2022 10:03pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thanks
Douglas
No its not a pain to replace see https://www.fullfatrr.com/forum/topic55392-45.html
If you remove the intake its even easier.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #630847 6th May 2022 10:05pm
dhallworth
Agreed.
The most awkward part of the whole job was getting the plug back in but it wasn’t a pain as such - just awkward.
Easy enough, just don’t rush it.
IIRC, it’s a 3/16th Allen key you need to remove the fill plug too. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #630848 6th May 2022 10:20pm
Thanks all
Post #630849 6th May 2022 10:28pm
bigbo
Good point about the Allen key size.
Also do not over tighten, its not necessary it has an o ring. mine was tightened by a gorilla so was difficult to remove.
MG TF 2003
Post #630853 6th May 2022 11:19pm
dhallworth
More progress has been made today!
To get the timing cover off you need to remove the air con compressor and the bracket that holds it which is mounted to the block. Some Censored who has been in here before had cross threaded one of the bolts and it sheered whilst removing it so that’s going to need addressing before reassembly.
Other then that, disassembly has been very straight forward.
Here’s how the block looks this evening.
The heads are now both on the toolbox with the cams and timing gear.
Interestingly, the timing chains that go from the crank to the intake cams were still tight. It was both chains that link the intake and exhaust cams in each head that had a lot of slack in them.
With the heads off, you can actually see a difference in the way the inlet valves are seated in the heads.
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
Someone has definitely been in at this engine before. One of the bolts on the cam bearing caps was loose, half of the bolts on the exhaust manifolds were loose, and one of the cam caps was marked with black marker pen.
Unfortunately, I also think one of the camshafts is scrap.
Debating over a pint of Guinness what to do about the cams now. Am trying to decide between buying a couple of used ones off eBay in the hope I can make a decent set of buying new.
Cams for the old Rover V8’s were readily available aftermarket but these newer engines don’t seem to be available from anywhere other then LR at £350 each.
Post #630930 7th May 2022 8:26pm
