![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I was wondering about it learning driving style like the gearbox does (drive like you stole it and it holds the gears etc).
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
I recon you could use the 4x4 info screen to keep an eye on the height sensor readings…. At least roughly anyway….
Anybody used the adaptive dynamics reset function in the GAP IID tool? 2012 TDV8 Vogue (L322) |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 725 ![]() ![]() |
Seems like it won't go back to a softer ride now.
I’ve replaced my rears so have new genuine struts.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Overall it sounds as though an accelerometer is giving false signals, either moving in its mount or is faulty. If none loose then a test jig could be made to compare each accelerometer's output, otherwise purchase 1 new accelerometer then swap it about to see if the problem is cured anywhere. The one in the spare wheel well is readily accessible so would be the first one to replace with a new one. |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Responded to a couple of threads on this topic.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
so you have not inspected the fronts and they could still be the issue? whilst i appreciate the harshness feels like it is from both the rear and front if you have a knackered front it will throw off the rest of the system. suspension is weird and a problem from the front can seem to come from the rear and vise versa. without inspection you are just guessing. Personally i dont spend money or make decisions with guesses where ever possible. 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
Okay so it seems my one is on and off, sometimes it hard sometimes it's what I would describe as 'acceptable'
I had discounted the fronts when I read an older post about the fronts being an issue but feels like the rear. The reasons for that (for me) is that if I drive over those smaller speed humps (normally yellow) the fronts feel hard, followed by the rears feeling hard too. My logic is simply if the fronts were a problem then the rears would feel fine in that situation.
Something I feel is worth bearing in mind FFrr-lover is that there is a potential for 1 bad shock to throw out the whole system
Reidsr Member Since: 31 Dec 2021 Location: Aberdeen Posts: 10 ![]() ![]() ![]() |
I am on the same assumption. 1 bad shock could off put all inputs to the shocks via the CVD system! For me it would be the first thing to do is change my shocks at the front, expensive and risky but when reading through this forum its pointing in that direction for sure. Its just a costly gamble hence the reason i haven't gone through with it as of yet! It defiantly feels as though a shock has become stuck and in turn puts all sorts of weird reading to the accelerometers. |
Yeeeeeah….. that looks to be where we are at. That or changing accelerometers just in case… before taking the plunge….
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Are the fronts more expensive than the rears? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
