Home > Maintenance & Mods (L322) > Clunk from front after new tyres |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Just replaced all four of my tyres and now then I perform a low speed turn in either direction I get a series of metallic clunks from somewhere up front.
29th Apr 2022 12:52pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I’d check those bushes and arms again, just to be sure. Maybe the heavy handed tyre fitters disturbed things enough for the problem to now show?
29th Apr 2022 1:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
curious to know how the tyre fitters jacked it up....
29th Apr 2022 1:44pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
do you get it when its stationary and you turn the steering.
29th Apr 2022 1:52pm |
In answer to the above. I took the wheels off (as per my blog - link below) and had them refurbished and fitted with new tyres.
29th Apr 2022 2:23pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
Nothing to do with wheel balance weights by any chance. |
29th Apr 2022 4:40pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1183 |
One possible cause is when the lower suspension arms were replaced, they could have been torqued up then the car lowered back onto the suspension. The new arms should be fitted then the weight of the car put onto the suspension, then the bolts torqued up. OR these may have been disturbed when the new tyres were fitted. Sounds are like hard heavy clunks when on slow full steering input turns, ie to get out of a driveway, maybe worth checking. Hope this helpful. |
29th Apr 2022 5:44pm |
Found it, one of the lower arms inner pinch bolt wasn't tightened up enough.
9th May 2022 7:26pm |
