Home > Maintenance & Mods (L322) > Clunk from front after new tyres
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Just replaced all four of my tyres and now then I perform a low speed turn in either direction I get a series of metallic clunks from somewhere up front.
Hard to tell where from due to being in the driver seat to make the car make the noise.
Both lower arms, and balljoints recently replaced (good ones).
Drop links were done by previous owner (so so ones)
Any ideas what else it could be?
Literally only seems to have started once the new tyres were fitted. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #630086 29th Apr 2022 12:52pm
JayGee
Does it happen steering in both directions?
Sorry I didn't read the post properly. Embarassed
I'd first check the wheel nuts are the proper torque 2012 TDV8 Vogue (L322)
Post #630090 29th Apr 2022 1:05pm
Ffrr-lover
I’d check those bushes and arms again, just to be sure. Maybe the heavy handed tyre fitters disturbed things enough for the problem to now show?
My front bushes and control arms were changed about 4,000 miles ago, but I’ve been told one is split (a brake test clonked and he then took a look) but I’ve yet to get under to see for myself.
It is possible that something has prematurely worn. Even good parts properly fitted can sometimes fail.
Maybe check all bolts are secure too while you are there… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #630092 29th Apr 2022 1:15pm
curious to know how the tyre fitters jacked it up....
something could have been damaged in the process. ... - .- -.
Post #630098 29th Apr 2022 1:44pm
Bingo_123
do you get it when its stationary and you turn the steering.
or is it only while moving (suspension travel)
Post #630099 29th Apr 2022 1:52pm
Caesium
In answer to the above. I took the wheels off (as per my blog - link below) and had them refurbished and fitted with new tyres.
Car sat on stands for about 10 days.
I refitted wheels. Torqued up fine.
Nothing else done, was perfect before. Christian.
Current Cars
2019 BMW X4
or
Post #630101 29th Apr 2022 2:23pm
Nothing to do with wheel balance weights by any chance.
Post #630106 29th Apr 2022 4:40pm
Merchy
One possible cause is when the lower suspension arms were replaced, they could have been torqued up then the car lowered back onto the suspension. The new arms should be fitted then the weight of the car put onto the suspension, then the bolts torqued up. OR these may have been disturbed when the new tyres were fitted. Sounds are like hard heavy clunks when on slow full steering input turns, ie to get out of a driveway, maybe worth checking. Hope this helpful.
Post #630109 29th Apr 2022 5:44pm
Caesium
Found it, one of the lower arms inner pinch bolt wasn't tightened up enough.
Getting that extra 90 degrees on after torqueing is so difficult. Christian.
Current Cars
2019 BMW X4
or
Post #631116 9th May 2022 7:26pm
