![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
JohnW Member Since: 28 Apr 2021 Location: Peterborough Posts: 27 ![]() ![]() ![]() |
Thanks for that, checked, they are closed today but will give them a ring. But at least I now have an excuse to take the car for a jolly on the motorway every other week |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
A…Wales,
AndesinWales Member Since: 24 Sep 2021 Location: Monmouthshire Posts: 9 ![]() ![]() ![]() |
That sounds like a good solution.. Thanks. |
Update to my DPF red triangle
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
Hi John,
Almost a month now and car still running perfectly. Not really been out of town so DPF been up twice and immediately been on the motorway to clear it and within 20 minutes its gone. Not risking it again!! Loving the car but reading some issues some have had when MOT comes up I am panicking. This is 11 years old with 181K on the clock, passed its MOT in Nov so may sell it soon as everything works perfectly, best sell before anything goes wrong. Maybe see if I can buy a younger version. 2011 4.4TDV8
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi all,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Any yellow dpf lights? If not, don't monitor or risk going bonkers about soot |
No yellow lights, just trying to track down poor mpg on my car. I’d like to know if it’s excessively regen’ing… or at least eliminate all things DPF from my investigations! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Duplicate post 2012 L322 4.4 TDV8 AB low mileage - a peach
There are a lot of factors and behaviour varies. I have spent 3 years monitoring it and getting a handle on it.
Many thanks for the replies DrRob and Range Rover L322
The trip should be pretty accurate vs calculated. The ECU is programmed to be 7% optimistic but you can reset this with the GAP IID tool and mine is now within <1mpg of the actual measured mpg. 2012 TDV8 Vogue (L322) |
On the MPG issue, if I reset my trip on the motorway, the dash will read 40mpg.
