![]() | Home > Technical (L322) > The saga continues... now gearbox issues maybe...? |
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
What do we think of the chances of page 12 being relevant here?
Unlikely unless you have about a 5mm tread depth difference between the front tyres. 2012 TDV8 Vogue (L322) |
I assumed the fronts have same make on each corner? 2012 TDV8 Vogue (L322) |
Sorry - you are right, Same make, same size, same pressures (may be different ages) currently on the front, which I agree makes this issue less likely. But has to be worth a try to change the brand new rears to the front and see?
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Have you researched the 4 mechatronic tube seals and the block seal, these seem to be a common issue, losing pressure. Also, the shift solenoids can fail. I don't know what the symptoms of each individual part failure causes
So, a bit of fiddling today with hawkeye plugged in.
I’d definitely swop the rears to the front and retest. 2012 TDV8 Vogue (L322) |
Definitely.
If it drifts to one side then there is definitely something wrong. 2012 TDV8 Vogue (L322) |
So... to come back to this. I got home a few weeks ago and parked the RR up and used the D3 instead.
