![]() | Home > Maintenance & Mods (L322) > Harsh ride!! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
When I had a knackered strut, I also had a lively rear end that would skip around corners if on anything other than smooth tarmac. When it hit those imperfections it would crash right through the chassis. Far more pronounced than stiff suspension.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I had the same issue. It was a front damper; I could see the bonnet being jittery. There wasn’t any oil leaking so something failed inside, most likely a jammed solenoid in the damper itself so it was stuck on ‘hard’ despite the ECU giving it the signal to open 1995 4.6 v8, green/tan (long gone)
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Update so far.
Well I changed the bushes top and.bottom, I also changed the rear anti roll bar links. The car drives much much better now, no squeaking either. |
Replacing the 7yr old front tyres with <5mm tread with new ones ( same Scorpion verde) made a substantial difference to the harsh low speed ride on mine. So much so I'm considering doing the same on the rears even though they are >5mm left. Not sure if this is age related or newer tyre design. An inspection revealed various worn bushes and dampness on the rear shocks but until I start getting knocks and clunks over bumps and actually feel like the rear is undamped I'll leave alone for now. 2012 TDV8 Vogue (L322) |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 ![]() ![]() ![]() |
I’m having similar issues with a bone shuddering judder from the back end when going over any bumps or pot holes (the roads around the Lake District are awful).
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7898 ![]() ![]() ![]() |
Continuously Variable Dampers….
From what I've seen the wires wear/break at the top of the mounts, mainly the front mounts, I think you get an adaptive dynamic fault though when they break. |
What I’m finding is at low speeds over the likes of speed bumps the back end is very bouncy, hit a pot hole at a relatively high speed and it feels like the vehicle is completely ridged with no give what-so-ever in the suspension. It’s like it’s trying to over compensate at speed?
When you hit the speed bumps, does the front bounce also? Or just the rears?
One suggestion to give is to see if it is the CVD system. You can do this by disabling it and comparing the ride / bounce etc Others have reported that turning off DSC (stability control) via the dash button does this (however I have not seen that this works myself) or pop the connector out of one of the top front struts (2 min job) to invoke a CVD failure. She’ll then run with the CVD system off. Simply reattach the connector to return to “normal” Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Ffrr-lover many thanks for the suggestions. I’ll try it out and report back. Out of interest what mileage was your vehicle on when you swapped out those shocks? |
My shock was shot when I bought the car at around £115k miles.
