![]() | Home > My Range Rover > Bournville TDV8 Vogue |
Jamze Member Since: 09 Feb 2019 Location: Uffington, Oxfordshire Posts: 17 ![]() ![]() ![]() |
https://www.amazon.co.uk/gp/product/B078J7...&psc=1
Sorting the tailgate supports this afternoon.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
Later 322s have a damper on the right and it fixes on to the ball. Maybe you have a mismatch between the supports etc and that accounts for the different lengths, as they should obviously be the same and the tailgate should be level. Only Range Rovers since 1988 |
Thanks. So not needed on mine, unless I do the damper upgrade. Doesn't explain the different lengths though. I'll try and return both these and order two of the standard supports. 2008 3.6 TDV8 Vogue Bournville |
Just taken them off again to double-check as it's bugging me |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 431 ![]() ![]() ![]() |
Hello, spotted this tread and thought it maybe a good place to ask - how purple does Bournville Brown look in reality? (If at all). |
You need sunlight, then stand at the right angle to catch the sunlight reflecting off the car, then squint, with any luck you will see it in browny purple |
Good to know! I have spotted a Bournville L322 but I live quite far from it so wanted an opinion on the colour. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
When clean and in bright sunlight mine has a deep red component but as it's mostly quite dirty others think that it's black. |
Ok great, I like the idea of brown, less so of purple! |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
In the right light it looks stunning; as others have said there is a reddish colour but also a deep chocolatey (hence the name!) The challenge is to get right light. In cloudy GB, it mostly looks black. I had a Bournville RRSand the colour really suited it. |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
