Home > My Range Rover > Bournville TDV8 Vogue |
Jamze Member Since: 09 Feb 2019 Location: Uffington, Oxfordshire Posts: 17 |
https://www.amazon.co.uk/gp/product/B078J7...&psc=1
13th Feb 2019 8:35pm |
Sorting the tailgate supports this afternoon.
18th Feb 2019 5:27pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
Later 322s have a damper on the right and it fixes on to the ball. Maybe you have a mismatch between the supports etc and that accounts for the different lengths, as they should obviously be the same and the tailgate should be level. Only Range Rovers since 1988 |
18th Feb 2019 6:01pm |
Thanks. So not needed on mine, unless I do the damper upgrade. Doesn't explain the different lengths though. I'll try and return both these and order two of the standard supports. 2008 3.6 TDV8 Vogue Bournville |
18th Feb 2019 6:22pm |
Just taken them off again to double-check as it's bugging me Started wondering if my lower tailgate was crooked or something. Old knackered one at the top. Below is the LR replacement (part LR038051). Def 10mm longer than the original one. Weird.
18th Feb 2019 9:54pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
Hello, spotted this tread and thought it maybe a good place to ask - how purple does Bournville Brown look in reality? (If at all). |
13th Apr 2022 10:15am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
You need sunlight, then stand at the right angle to catch the sunlight reflecting off the car, then squint, with any luck you will see it in browny purple All throughout my ownership of a "Bourneville" I had to work hard to convince people that it was not black. .
13th Apr 2022 10:30am |
Good to know! I have spotted a Bournville L322 but I live quite far from it so wanted an opinion on the colour. |
13th Apr 2022 11:16am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2519 |
When clean and in bright sunlight mine has a deep red component but as it's mostly quite dirty others think that it's black. |
13th Apr 2022 11:21am |
Ok great, I like the idea of brown, less so of purple! |
13th Apr 2022 11:24am |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1032 |
In the right light it looks stunning; as others have said there is a reddish colour but also a deep chocolatey (hence the name!) The challenge is to get right light. In cloudy GB, it mostly looks black. I had a Bournville RRSand the colour really suited it. |
13th Apr 2022 11:41am |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 |
Hi,
13th Apr 2022 12:21pm |
