Home > My Range Rover > Bournville TDV8 Vogue
Jamze
United Kingdom 2008 Range Rover Vogue TDV8 Bournville
https://www.amazon.co.uk/gp/product/B078J7...&psc=1
This was the one, but there are loads similar. Note it's an FM transmitter - pick a frequency on your radio with nothing on it. Sounds pretty good (well, as good as the FM radio does). It does phone calls too, but I don't use that - would rather hide it away in the cubby.
 2008 3.6 TDV8 Vogue Bournville
Post #505057 13th Feb 2019 9:35pm
Jamze
So, to-do list on my Bournville...
- Replace one of the tailgate supports. One is damaged, took a look today, tophat bush has fallen apart and it no longer folds away properly when you shut the lower tailgate - hence the damage.
- Sort the mudflaps/lower wing panels. They're poorly fitted, noticed one of the panels rubs on the door and has taken a bit of paint off. I'd remove the flaps, but family like the steps.
- Rear discs pretty corroded. Still seem to work ok, but I'll prob replace discs and pads.
- Get to know the local indy, service and check over.
Not too bad at all. 2008 3.6 TDV8 Vogue Bournville
Post #505060 13th Feb 2019 10:02pm
Jamze
Sorting the tailgate supports this afternoon.
Has anyone got lower tailgate supports like this on their L322? I've put on a pair of new ones, sold as genuine LR ones. The new RHS one has this different bolt with a ball on it, I assume to keep the rubber boot in place. But the left one doesn't have this, it's just the same as the old ones.
Also, the right one is now shorter (slightly) than the left - so if I stand on the tailgate it will twist. Something's not right.
Post #505593 18th Feb 2019 6:27pm
CS
Later 322s have a damper on the right and it fixes on to the ball. Maybe you have a mismatch between the supports etc and that accounts for the different lengths, as they should obviously be the same and the tailgate should be level. Only Range Rovers since 1988
Post #505595 18th Feb 2019 7:01pm
Jamze
Thanks. So not needed on mine, unless I do the damper upgrade. Doesn't explain the different lengths though. I'll try and return both these and order two of the standard supports. 2008 3.6 TDV8 Vogue Bournville
Post #505600 18th Feb 2019 7:22pm
Jamze
Just taken them off again to double-check as it's bugging me Smile Started wondering if my lower tailgate was crooked or something. Old knackered one at the top. Below is the LR replacement (part LR038051). Def 10mm longer than the original one. Weird.
Post #505614 18th Feb 2019 10:54pm
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hello, spotted this tread and thought it maybe a good place to ask - how purple does Bournville Brown look in reality? (If at all).
Post #628550 13th Apr 2022 11:15am
You need sunlight, then stand at the right angle to catch the sunlight reflecting off the car, then squint, with any luck you will see it in browny purple Smile All throughout my ownership of a "Bourneville" I had to work hard to convince people that it was not black. Thumbs Up .
Post #628552 13th Apr 2022 11:30am
KitTheRam
Good to know! I have spotted a Bournville L322 but I live quite far from it so wanted an opinion on the colour.
Post #628558 13th Apr 2022 12:16pm
GraemeS
Australia
When clean and in bright sunlight mine has a deep red component but as it's mostly quite dirty others think that it's black.
Post #628559 13th Apr 2022 12:21pm
KitTheRam
Ok great, I like the idea of brown, less so of purple!
Post #628562 13th Apr 2022 12:24pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
In the right light it looks stunning; as others have said there is a reddish colour but also a deep chocolatey (hence the name!) The challenge is to get right light. In cloudy GB, it mostly looks black. I had a Bournville RRSand the colour really suited it.
Post #628576 13th Apr 2022 12:41pm
RiverBlanche
Hi,
I think it is one of the best colours going, Thumbs Up along with an Ivory interior Cool
but its a colour that does not photograph well, it needs to be seen in the flesh then decide,
a friend has had their horse box sprayed in it but its more brown dont think they got the metallic element quiet right Question
Post #628584 13th Apr 2022 1:21pm
