Home > Maintenance & Mods (L322) > Cleaning undercarriage
redsportt
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
whats the best way of cleaning the undercarriage? just noticed some rust and crud on subframes and nuts bolts etc
Any good ideas?
Post #628353 11th Apr 2022 11:36am
mpirie
No good ideas, but plenty of jokes about cleaning your undercarriage and nuts! Rolling with laughter Rolling with laughter Rolling with laughter
Mike
Post #628354 11th Apr 2022 11:44am
mjdronfield
I know someone posted on here about a trolley brush type thing you connected to a hose or pressure washer and you wheeled it about under the car.
Not tried one, but it would get mud etc off.
You’d have to get more hands on I think if you want to treat any surface rust etc.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #628355 11th Apr 2022 11:48am
mjdronfield
https://www.fullfatrr.com/forum/topic17956...=underside
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #628356 11th Apr 2022 11:55am
garyRR
Off road height.
Spray degreaser mixed with hot water from a garden sprayer
Pressure wash off with one that has a 45-90 degree elbow attachment? Mine does.
--> next time you service something underneath, pick a new spot, grab a brush, degreaser and brake cleaner and spend 5 mins giving that area a good old scrub. All my sub frames are clean now and all the road grime on the gearbox is also now gone, through doing 5 mins here and there. 2015 Range Rover Autobiography 4.4 SDV8
Post #628396 11th Apr 2022 6:52pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
when i did mine i did have a 4 post ramp at hand in the workshop and took me a couple of weeks to clean it all down
i used a lot of wire brush items that fits in to a drill and just keep going over and take your time when you have a area done spray or paint on some of the many types of rust removal types of spray or paint . and then i used a lot of wax oil items through a schultz gun and put a lot on over to days i put on over 30 ltrs of protection under side and in side box sections etc .when i put it in for my first mot they could not believe how good the underside was looking i think they said wow what a job . but then i have been doing cars and spraying all my life that could have something to do with it i suppose i say if you are going to do something do it to the very best you can. i used a lot of pure 15 items which is acid base after cleaning down with wire items new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #628400 11th Apr 2022 7:31pm
Merchy
I think oggy has hit the nail on the head, there really is no short, easy way to do this properly, like a lot of jobs, at the end of the day it involves lots of time and elbow grease Big Cry
Post #628404 11th Apr 2022 8:07pm
dhallworth
I’ve just done mine. There’s no quick way to do it.
I removed my subframe, wishbones, etc and sent them away for shot blasting before using Bilt Hamber Epoxy Mastic to paint it.
If you’ve got access to a ramp you might be able to do it in situ but working underneath it whilst lying on your back will not be easy nor a pleasant job.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #628406 11th Apr 2022 8:13pm
