Home > Technical (L322) > Horrible sight
Fox889
It takes literally 30 seconds to remove the MAP sensor off the plenum, if it looks gummed up & the hole in the plenum is blocked up, odds on yours needs a clean up.
I've read people on here say they clean their MAP sensor on a yearly basis, something I shall now be doing as well.
Have a look & see what lurks beneath Smile
I've got a few photos but dare say someone on here will have a better guide.
Let me know if you want any photos. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #628133 8th Apr 2022 9:46pm
JayGee
I clean my MAP sensor every 2-3k miles. Also you can remove the elbow to the throttle plate and check the state of fouling on it (My plate was very clean). 2012 TDV8 Vogue (L322)
Post #628134 8th Apr 2022 9:57pm
garyRR
So as it's a sunny Saturday for once and definitely wasn't prepared to go and see Saints lose 6-0, I did a bit of a health check.
The MAP sensor was slightly caked up but not bad. Anyway, cleaned up and back in.
Took off the elbow and was all pretty clean inside - just that little bit of residue which I cleaned up then put it all back together.
 2015 Range Rover Autobiography 4.4 SDV8
Post #628194 9th Apr 2022 4:46pm
JayGee
Bottom right of picture look like intake gunk - your throttle elbow joint may be leaking? 2012 TDV8 Vogue (L322)
Post #628205 9th Apr 2022 5:47pm
garyRR
When I took it off, i noticed it wasn't seated on the throttle body properly. When I put it back, I made sure it was the whole way on. 2015 Range Rover Autobiography 4.4 SDV8
Post #628216 9th Apr 2022 8:01pm
JayGee
Should run better with that sealed up properly. 2012 TDV8 Vogue (L322)
Post #628247 10th Apr 2022 7:55am
