Home > Technical (L322) > Horrible sight |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3254 |
I clean my MAP sensor every 2-3k miles. Also you can remove the elbow to the throttle plate and check the state of fouling on it (My plate was very clean). 2012 TDV8 Vogue (L322) |
8th Apr 2022 9:57pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
So as it's a sunny Saturday for once and definitely wasn't prepared to go and see Saints lose 6-0, I did a bit of a health check.
9th Apr 2022 4:46pm |
Bottom right of picture look like intake gunk - your throttle elbow joint may be leaking? 2012 TDV8 Vogue (L322) |
9th Apr 2022 5:47pm |
When I took it off, i noticed it wasn't seated on the throttle body properly. When I put it back, I made sure it was the whole way on. 2015 Range Rover Autobiography 4.4 SDV8 |
9th Apr 2022 8:01pm |
Should run better with that sealed up properly. 2012 TDV8 Vogue (L322) |
10th Apr 2022 7:55am |
