Home > Technical (L322) > Horrible sight
Fox889
It takes literally 30 seconds to remove the MAP sensor off the plenum, if it looks gummed up & the hole in the plenum is blocked up, odds on yours needs a clean up.
I've read people on here say they clean their MAP sensor on a yearly basis, something I shall now be doing as well.
Have a look & see what lurks beneath Smile
I've got a few photos but dare say someone on here will have a better guide.
Let me know if you want any photos. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #628133 8th Apr 2022 9:46pm
JayGee
I clean my MAP sensor every 2-3k miles. Also you can remove the elbow to the throttle plate and check the state of fouling on it (My plate was very clean). 2012 TDV8 Vogue (L322)
Post #628134 8th Apr 2022 9:57pm
garyRR
So as it's a sunny Saturday for once and definitely wasn't prepared to go and see Saints lose 6-0, I did a bit of a health check.
The MAP sensor was slightly caked up but not bad. Anyway, cleaned up and back in.
Took off the elbow and was all pretty clean inside - just that little bit of residue which I cleaned up then put it all back together.
 2015 Range Rover Autobiography 4.4 SDV8
Post #628194 9th Apr 2022 4:46pm
JayGee
Bottom right of picture look like intake gunk - your throttle elbow joint may be leaking? 2012 TDV8 Vogue (L322)
Post #628205 9th Apr 2022 5:47pm
garyRR
When I took it off, i noticed it wasn't seated on the throttle body properly. When I put it back, I made sure it was the whole way on. 2015 Range Rover Autobiography 4.4 SDV8
Post #628216 9th Apr 2022 8:01pm
JayGee
Should run better with that sealed up properly. 2012 TDV8 Vogue (L322)
Post #628247 10th Apr 2022 7:55am
