Home > Maintenance & Mods (L405) > 2014 RR L405 suspension lowering |
Sester Member Since: 20 May 2019 Location: Doncaster Posts: 87 |
15th Mar 2022 7:42pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2493 |
I assume that LR called the module the chassis module because as well as the suspension ecu it contains the CVD ecu which is powered by the 15A fuse 23. |
15th Mar 2022 7:51pm |
Thanks, I take it the one I’ve taken out (10amp) is the right one yes ? |
15th Mar 2022 7:59pm |
Good morning, so I’ve come out to my car and the rear of the car is fully lowered on both sides ?
16th Mar 2022 7:03am |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 288 |
More likely to be the rear valve block.
16th Mar 2022 7:48am |
Oh….
16th Mar 2022 8:18am |
It will be in the Workshop Manual which is available in the Wiki. Looks like it may be by the rear NS air spring.
16th Mar 2022 8:26am |
Got the motor booked in !
17th Mar 2022 6:53am |
Hi all sorry not fed back sooner.
31st Mar 2022 12:01pm |
Well, finally found the problem !!!
5th Apr 2022 7:35pm |
RutlandBoy Member Since: 20 Mar 2022 Location: East Northants Posts: 31 |
Hi,
5th Apr 2022 9:42pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
If the car is slightly on the tilt/parked on an incline then it will often keep trying to level itself and gradually dump itself on the floor...
6th Apr 2022 1:21am |
Thanks,
6th Apr 2022 5:14am |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 |
Sester can you not use one of these inline air hose couplers where you have the pinhole leak as an interim solution until a new tube arrives, just cut the tube at the hole and push both ends into the coupler, they are sold in a variety of diameters, must be available at your local hydraulics / pneumatics supplier, just identify your tube diameter..
6th Apr 2022 6:00am |
