Home > Maintenance & Mods (L405) > 2014 RR L405 suspension lowering
Page 2 of 3 <123>
knwatkins
Ah that's interesting but contradicts the manual I was reading last night. Great that you found the fuse. Fingers crossed for you. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #626249 15th Mar 2022 7:37pm
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
This is the manual I found and used in the photo.
The fuses matched from the manual to what was in the upper fuse board so I can only assume I got it right ?
You guys said a 10amp in number 20 so I think I got it right 🙏
I’ll soon see 😂
Post #626250 15th Mar 2022 7:42pm
GraemeS
I assume that LR called the module the chassis module because as well as the suspension ecu it contains the CVD ecu which is powered by the 15A fuse 23.
Post #626251 15th Mar 2022 7:51pm
Sester
Thanks, I take it the one I’ve taken out (10amp) is the right one yes ?
Post #626252 15th Mar 2022 7:59pm
Sester
Good morning, so I’ve come out to my car and the rear of the car is fully lowered on both sides ?
Am I right to assume BOTH rear bags are faulty 😩
Post #626263 16th Mar 2022 7:03am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
More likely to be the rear valve block.
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #626265 16th Mar 2022 7:48am
Sester
Oh….
Where is that please ?
How do I test for that ?
I’d hoped I’d left the suspension issues in my past with the L322 😩
Post #626266 16th Mar 2022 8:18am
IGP
It will be in the Workshop Manual which is available in the Wiki. Looks like it may be by the rear NS air spring.
HTH
Post #626268 16th Mar 2022 8:26am
Sester
Got the motor booked in !
Had an “adaptive dynamics fault” spring up this morning is this linked 🙄
Post #626360 17th Mar 2022 6:53am
Sester
Hi all sorry not fed back sooner.
So, we found a very slight leak in the OSR bag.
Had two new ones fitted BUT, still going down and it’s quicker now ?
What’s the next part that I need to change do you guys think 😩🤦🏻
Post #627446 31st Mar 2022 12:01pm
Sester
Well, finally found the problem !!!
There’s a pin hole in one of the air suspension tubes (osr) !!!
And to make matters worse, I can’t find one in the Uk !!!!!
No dealers have one, Duckworths don’t have one, at least 15 other independent LR specialists don’t have one !!!!
I’m dumbfounded!!!
Apparently there on back order with no date suggested.
Question, does anyone recommend where I could try ?
Part no. Is LR045736.
Or, could I have one made?
Or, can anyone advise how to repair as a temp fix?
Was thinking something like a self sealing silicone tape or something?
Please help 🙏
Post #627838 5th Apr 2022 7:35pm
RutlandBoy
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Hi,
No idea if this helps or not but just checked rimmerbros and
They say its in stock at their suppliers - but of course that might not be right - or you may have already tried them, in which case - sorry to have wasted your time !
Good luck ! L405 4.4 V8 Vogue SE Santorini Black
RRS L390 4.2 S/C Stornoway Grey
Classic Range Rover Overfinch 5.7 - their first prototype - under restoration
Late Range Rover P38
Range Rover 3.9 Classic Softdash
Range Rover Classic Overfinch 5.7 - Sadly gone
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #627850 5th Apr 2022 9:42pm
If the car is slightly on the tilt/parked on an incline then it will often keep trying to level itself and gradually dump itself on the floor...
Does the car just drop to the lower level or drop to the bump stops? The latter is worse...
Post #627862 6th Apr 2022 1:21am
Sester
Thanks,
Tried Rimmer Bros they don’t have one ☹️
The car drops down on the osr due to this leak.
Do you think some sealing repair tape might maintain it until I can get the part !?
Post #627865 6th Apr 2022 5:14am
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Sester can you not use one of these inline air hose couplers where you have the pinhole leak as an interim solution until a new tube arrives, just cut the tube at the hole and push both ends into the coupler, they are sold in a variety of diameters, must be available at your local hydraulics / pneumatics supplier, just identify your tube diameter..
Post #627871 6th Apr 2022 6:00am
Page 2 of 3 <123>
