Home > Maintenance & Mods (L405) > 2014 RR L405 suspension lowering
Page 1 of 3 123>
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
Hi all, strange one this,
I’ve noticed that my RR is lowering its suspension to the ground when it’s been left a few days 🤔
It’s never done this before ?
When I start it up, suspension raises to correct level and stays there with no issues.
There’s no warnings or faults flagging up and it works fine moving to all three levels ?
Any help / advice greatly received!
Thanks
Post #626160 14th Mar 2022 6:40pm
mpirie
It could be a slow leak in one of the air struts.
Mike
Post #626170 14th Mar 2022 8:33pm
Sester
Not what I like to hear 😭
It’s the whole car though not just one corner 🤔
Is there a way to check them ?
Thanks for your help
Post #626171 14th Mar 2022 8:35pm
CS
All my air suspension RRs have done this when a bit older, say after 5 years. I just put up with it and have only ever had to replace one air suspension bag, which tore when the wheels were hanging down when the car was on the dealer's lift. When my first 322 was about nine yo it took a while to get up to height again, one had to leave it to idle for a while before driving off, but once there it worked well enough.
It might be worth your while searching for threads about compressor seal leaks too. I recall people talking about putting the car on the highest setting and then putting soapy water on the air bags to see if any bubbles could be noticed, but I've never done that myself. Apparently they can get a bit porous with age, especially on the sections that compress and decompress as the car rises and falls. If you have auto lowering to access height when the engine is switched off there might be more wear too, I disabled that function as I don't need or want it. Only Range Rovers since 1988
Post #626172 14th Mar 2022 8:55pm
Sester
Auto access ??? Where’s that setting please ?
Mines a 2014 does it have it ?
I can live with it cos it works fine, rises and lowers fast enough etc.
Is there a way of testing for leaks on pump seals ?
Thanks
Post #626173 14th Mar 2022 9:06pm
mpirie
If you spray soapy water on any of the air lines/valves/bags then a small leak will show up as bubbles.
You may be able to live with it now, but at some point a small leak could become a big leak and leave you stranded.
Mike
Post #626175 14th Mar 2022 9:32pm
Sester
Thanks for your reply !
I’ll try to do what you’ve advised.
I take it one bag leak would cause the whole car to drop ?
Would it not flag a warning or fault up ?
Post #626176 14th Mar 2022 9:46pm
GraemeS
Australia
If one air-spring is leaking then to a point the other corners will gradually lower to keep the vehicle level. Removing the 10A suspension system fuse (#20 in the rear fuse panel) overnight will reveal a sinking corner.
Post #626178 14th Mar 2022 9:57pm
Sester
That’s a great help !
Where is the rear fuse box situated ?
Just looked at this link, number 20 in either box is sunroof or alternator?
https://topix.landrover.jlrext.com/topix/c...e-mobile=1
Thank you very much all for your help & advise thus far !
Post #626180 14th Mar 2022 10:03pm
knwatkins
Not on a 2014.
Rear fuse box is behind the right hand side boot trim panel which is held on by three or four clips at the top. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #626182 14th Mar 2022 10:08pm
Sester
Didn’t think it had it !
Is it fuse no. 20 in the rear fuse box as the link in my previous post doesn’t say no. 20 has anything to do with suspension?
It doesn’t even have a no. 20 in rear fuse box 🤔
Post #626186 14th Mar 2022 10:20pm
knwatkins
There are two fuse boxes behind the panel, an upper one above the auxiliary battery and a lower one inside the rear quarter void. You are right in that the fuses in the upper one only go up to 16. However, in the lower one they go up to 30.
Fuse 20 is a red 10A fuse for the Chassis Control Module. Kev
Post #626189 14th Mar 2022 10:38pm
Sester
Fantastic!
I’ll remove that one over night and see what happens!
Thank you all very much for your support !
Post #626190 14th Mar 2022 10:43pm
Sester
Please can you give me a clue which fuse it is I need to remove ?
I’ve found the fuse board in the rear quarter area but don’t know which one I need to take out and can’t find a diagram 🤦🏻
I’ve added a photo of the fuse board to confirm it’s the right one !
Post #626230 15th Mar 2022 3:46pm
Sester
**update**
I’ve found a diagram and by the process of elimination I’ve removed a 10amp fuse.
The chassis control unit fuse on the diagram is number 20 and it’s in the upper fuse board in the rear right not the one I sent the photo of in the previous post.
I’ll leave the car now and see what happens !
Post #626235 15th Mar 2022 4:59pm
Page 1 of 3 123>
