Home > Maintenance & Mods (L322) > NSF Creak when steering and over bumps
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Those of you that have followed my project page will know that I have changed all the arms and balljoints on my car already, but it's now developed a really loud creaking when steering or over bumps.
Before I get it up in the air to have a look, does anyone have any pointers to what this could be?
I'm thinking perhaps strut top mount? Not sure what else could be at fault there as it's all been on the car less than 6 months and only do ne about 1800 miles. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #625530 6th Mar 2022 5:03pm
Caesium
This is the creak and it's the bottom balljoint that's part of the lower arm.
They were changed in October last year and have done about 1200 miles. They're Britpart.
[/url] Christian.
Current Cars
2019 BMW X4
or
Post #625606 7th Mar 2022 2:25pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
Sounds exactly like mine did
Post #625631 7th Mar 2022 6:15pm
Caesium
I cannot believe those arms have failed in less than 1300 miles. Shocking. Christian.
Current Cars
2019 BMW X4
or
Post #625632 7th Mar 2022 6:21pm
dhallworth
They’re not called Censored for no reason Smile
I’ve just replaced everything on the front of mine. In the arms without the ball joints I replaced the bushes and in the arms with the ball joints I replaced the whole arm. Genuine LR are readily available or Island 4x4/Advanced Factors have Lemforder parts readily available too (I read somewhere Lemforder make them for LR).
Post #625642 7th Mar 2022 7:35pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
BritPart did you say?..... I can! Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #625649 7th Mar 2022 8:27pm
Caesium
Got both the arms off the car now:
 Christian.
Current Cars
2019 BMW X4
or
Post #625871 9th Mar 2022 10:17pm
Sandyt
Remember to torque up the bolts with the arms under load ie not jacked or they will be toast in a couple of thousand miles
Post #625905 10th Mar 2022 2:13pm
Caesium
Yes that’s quite clearly stated in the workshop manual as “in the normal driving position” which means not in off road or access mode, but on the ground in the normal driving position.
It’s worth noting that it’s only the bush end this applies to, not the balljoint end. Christian.
Current Cars
2019 BMW X4
or
Post #625907 10th Mar 2022 2:44pm
Mikey
That's what happens when you buy cheap...
For only £5 a side more, you could have gotten yourself Lemforder arms, which are OEM for L322
Yes, the cheap arms should have lasted more than 1300 miles, but when you buy the cheapest parts available, what else do you expect? Confused
Post #625920 10th Mar 2022 5:55pm
Caesium
Thanks. That's really helpful. Christian.
Current Cars
2019 BMW X4
or
Post #625921 10th Mar 2022 6:16pm
