Home > Maintenance & Mods (L322) > NSF Creak when steering and over bumps |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Those of you that have followed my project page will know that I have changed all the arms and balljoints on my car already, but it's now developed a really loud creaking when steering or over bumps.
6th Mar 2022 5:03pm |
This is the creak and it's the bottom balljoint that's part of the lower arm.
7th Mar 2022 2:25pm |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 |
Sounds exactly like mine did |
7th Mar 2022 6:15pm |
I cannot believe those arms have failed in less than 1300 miles. Shocking. Christian.
7th Mar 2022 6:21pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
BritPart did you say?..... I can! The older I get, the more I realise that people confuse wrinkles for wisdom |
7th Mar 2022 8:27pm |
Got both the arms off the car now:
9th Mar 2022 10:17pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Remember to torque up the bolts with the arms under load ie not jacked or they will be toast in a couple of thousand miles |
10th Mar 2022 2:13pm |
Yes that’s quite clearly stated in the workshop manual as “in the normal driving position” which means not in off road or access mode, but on the ground in the normal driving position.
10th Mar 2022 2:44pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1751 |
10th Mar 2022 5:55pm |
Thanks. That's really helpful. Christian.
10th Mar 2022 6:16pm |
