Home > In Car Electronics (L322) > Have i cocked up ?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Have i cocked up ?
Bought android for my 06 SE , is it going to be straightforward to fit or not ? Did some reading on here last night , got the impression it wont be plug and play ??? Its an e39 bmw unit im waiting for
Post #623548 13th Feb 2022 12:01pm
Danwilderspin
Have a look at my posts there was one about the story of sorting it Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #624678 24th Feb 2022 11:17pm
mjdronfield
Not sure when the fibre MOST system was introduced, 2005?. You will need the BMW iBus system in your car for the android unit for a BMW to work.
I’d normally ask if it’s a touchscreen in your car, but you might not have a screen….
Unless you are ripping stuff out and replacing as a whole.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #624692 25th Feb 2022 9:02am
Danwilderspin
incorrect - you will be able to get the bus feed from the clock which is one of a handful of units to retain it until the 2010 facelift. You will be able to. make it work. you will need to make a couple of harnesses from eBay - piece of cake I can find you some item numbers it will cost about £20.
Then you need to work out if you want to retain the existing sound system in which case you need an orca to most box (I may have one for sale) which is great but it maxes the volume so if you are young you may hear a little bit of high pitched interference. but it may have just been me. or you can buy a harness which will need a slight repin for a rr sport for around £50 and a 6 channel infinity or able amp and use the stock speakers. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #624705 25th Feb 2022 10:05am
mjdronfield
Far from plug and play then…..
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #624707 25th Feb 2022 10:17am
Danwilderspin
Tbf if you go down route one of the most adapter it takes about 10 minutes longer than a Bmw era one you just need to name together the three ready made harnesses to convert from Bmw pin layout to jlr.
But yes if you want to ditch most its a fair bit more involved. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #624709 25th Feb 2022 10:29am
bembo449
Mines the denso head unit which is ford era no ? I will appreciate any help i can get on this conversion, currently have the head unit out , cd changer , amp and BT unit
I thinking of making a speaker loom from the android down to the back so i can utilize the amp / speaker harness then i thought it would just be a case of power to run everything but as i say , i welcome all the advice / help anyones willing to give
Thanks
Simon
Post #624743 25th Feb 2022 5:22pm
mjdronfield
As a side thought, The stock speakers are fairly good and would handle a decent amp if you did end up adding one and wiring direct from the android head unit, bypassing factory stuff.
At least you can do something then, if you want to make up harnesses.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #624745 25th Feb 2022 5:54pm
bembo449
Thats good to know pal , i guess it would be wise to make my installation upgradable while im at it
Where is the best place to take the Accessor live from ???
Post #624788 26th Feb 2022 9:34am
bembo449
I have the denso screen which i presume is touch screen, i wouldn't know as its never worked
Post #624790 26th Feb 2022 9:36am
Danwilderspin
If you are doing amp you will need this and a slight repin to cater for the rear surrounds and subs
https://incartec.co.uk/product/20-314-LOGIC7
Something like this works good or an equivalent (the infinity one is identical with a different badge though)
https://www.amp-performance.de/en/273-JBL-GTO-6000.html
Then this is what you need for the headunit whatever :
https://www.ebay.co.uk/itm/RADIO-STEREO-HE...635-2958-0
https://www.ebay.co.uk/itm/Adapter-Quadloc...635-2958-0
And maybe this to mount somewhere? https://www.ebay.co.uk/itm/USB-2-0-dual-Ma...635-2958-0
You’ll want a decent 6channel 5m rca lead too, and a 1f to 2m rca adapter for the sub.
I really hope you went 10.25 screen to make the most of it.
When we’ve done these in the past as has been suggested the amp appears to have been the bottleneck not the speakers - the speakers are bloody brilliant and can take a beating. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #624865 26th Feb 2022 8:46pm
bembo449
Great info that pal exactly what i need , once i get into the job i will get an ifea what will be required 👍
Post #625031 28th Feb 2022 7:05pm
Danwilderspin
As the most adapters start at around £100 plus shipping you may be not far off the same money for something like this and the harness and rcas if you have the time
https://www.ebay.co.uk/itm/Jbl-Gto-755-6-A...635-2958-0 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #625034 28th Feb 2022 7:36pm
bembo449
Ok pal , really want to get stuck into it but the weather is garbage
Post #625035 28th Feb 2022 7:38pm
bembo449
got a genuine wiring harness coming and also broke open the harmon amp , guess what i found ???
Post #625248 3rd Mar 2022 4:31pm
