Home > In Car Electronics (L322) > Have i cocked up ? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Have a look at my posts there was one about the story of sorting it Current stable:
24th Feb 2022 11:17pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7798 |
Not sure when the fibre MOST system was introduced, 2005?. You will need the BMW iBus system in your car for the android unit for a BMW to work.
25th Feb 2022 9:02am |
incorrect - you will be able to get the bus feed from the clock which is one of a handful of units to retain it until the 2010 facelift. You will be able to. make it work. you will need to make a couple of harnesses from eBay - piece of cake I can find you some item numbers it will cost about £20.
25th Feb 2022 10:05am |
Far from plug and play then…..
25th Feb 2022 10:17am |
Tbf if you go down route one of the most adapter it takes about 10 minutes longer than a Bmw era one you just need to name together the three ready made harnesses to convert from Bmw pin layout to jlr.
25th Feb 2022 10:29am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Mines the denso head unit which is ford era no ? I will appreciate any help i can get on this conversion, currently have the head unit out , cd changer , amp and BT unit
25th Feb 2022 5:22pm |
As a side thought, The stock speakers are fairly good and would handle a decent amp if you did end up adding one and wiring direct from the android head unit, bypassing factory stuff.
25th Feb 2022 5:54pm |
Thats good to know pal , i guess it would be wise to make my installation upgradable while im at it
26th Feb 2022 9:34am |
I have the denso screen which i presume is touch screen, i wouldn't know as its never worked |
26th Feb 2022 9:36am |
If you are doing amp you will need this and a slight repin to cater for the rear surrounds and subs
26th Feb 2022 8:46pm |
Great info that pal exactly what i need , once i get into the job i will get an ifea what will be required 👍 |
28th Feb 2022 7:05pm |
As the most adapters start at around £100 plus shipping you may be not far off the same money for something like this and the harness and rcas if you have the time
28th Feb 2022 7:36pm |
Ok pal , really want to get stuck into it but the weather is garbage |
28th Feb 2022 7:38pm |
got a genuine wiring harness coming and also broke open the harmon amp , guess what i found ??? |
3rd Mar 2022 4:31pm |
