Home > Technical (L322) > Poor dip beam |
MonkeyMan Member Since: 20 Apr 2021 Location: Ascot Posts: 133 |
Are they the original bulbs? I find Xenon’s deteriorate over time (they did on my last car, not sure if that’s a general thing) it got to the point that when I was diving in dipped beam I was continually being blinded by oncoming traffic. Some new HID bulbs fixed that. |
26th Feb 2022 3:47pm |
Gary Williams Member Since: 17 Jan 2017 Location: Essex Posts: 53 |
The large, white cone is (I think) a ball joint that fixes the reflector so the two adjusters can move the reflector horizontally and vertically. Can the ballast resistor be changed for different values? |
26th Feb 2022 4:00pm |
Hi Monkeyman,
26th Feb 2022 4:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
The light is always the same on the Xenons, it doesn’t change from high to low beam, there is just a shutter used on dip so you don’t blind oncoming traffic.
26th Feb 2022 4:13pm |
A mechanical flap? Is this operated by a solenoid? Perhaps the flap may be adjusted? I'll have a look in the rave manual |
26th Feb 2022 4:20pm |
Yeah. If you flick from low to high beam without the engine on, you might be able to hear it. Ignition on… obviously.
26th Feb 2022 4:57pm |
I would be tempted to fit new bulbs. If you get them from Amazon or Halfords or similar with a fairly ope. Returns policy then it should be easy enough to take them back if that doesn’t solve the problem.
26th Feb 2022 6:54pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
My car is now 16 years old and has over 80,000 miles on it. No sign of headlights deteriorating! Previous cars:
26th Feb 2022 11:14pm |
Ahha! Engine off, ignition and lights on. Toggling between dip and main beams and you can really hear the two flaps banging up and down.
27th Feb 2022 11:58am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
I’d be tempted to not start messing about with the aim- MOT issues and the flaps for high beam….
27th Feb 2022 5:02pm |
On full beam, the xexon bulbs are incredibly bright and provide a very long beam in country roads. But dipped (shuttered) they do provide a large area of illumination of the road and roadside but at too low a level of illumination. I need decent hotspots on the road ahead and left hand kerb. I now have to drive with the fog lights on to see the left hand kerb with decent clarity.
28th Feb 2022 10:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
It sounds as though your headlight beams are set too high. Lowering them will improve things but would be better set up correctly either against a garage door or wall. You could even go to your local mot garage when they are quite and ask them to check / reset them. I don’t think you will get “hot spots” on dip beam with xenon’s but the light level should be more than adequate. Certainly l have no issue. |
28th Feb 2022 11:51am |
