Home > Technical (L322) > 2007 Supercharged Misfiring
Page 3 of 4 <1234>
dingg1
Check your connections at the pcv, its an inherent weakness in the design, I resorted to wrapping them in self amalgamating tape after lots of problems with air ingress
Post #622892 7th Feb 2022 6:10pm
dhallworth
Thanks Dingg.
The PCV was replaced last year as I could hear air in that general area but could never pin it down.
I’ll get it inside and do some more digging one evening this week if I can, if not, definitely at the weekend.
I’m going to try and make my own smoke tester so that I can give it a proper going over too. I had it smoke tested last year but they did it whilst I waited and didn’t find any leaks. Of course the car was hot when I got it there and seeing as it runs properly when it’s hot they didn’t find anything.
It’d be nice if I could finally put an end to it once and for all.
Post #622903 7th Feb 2022 7:35pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
David,
This isn’t connected to the original problem that you found when you first had the car is it? Coil packs etc as in the electrical feed to them? Could this be a engine bay wiring loom issue?
Regards
John
Post #622923 7th Feb 2022 9:32pm
dhallworth
I don’t think so but that’s a good thought…
When I got the car it just had 1 melted coil pack that I’m sure was just down to the insulation on the coil breaking down.
I’ve done best part of 6000 miles since I swapped them out. If it was an electrical issue I’d have thought it’d be present all the time like it was originally rather then just at idle.
Interesting thought though and one I hadn’t considered Thumbs Up
Post #622928 7th Feb 2022 10:20pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Hi David,
I have the same occasional issue with mine 4.4 ajv8 with LPG.
Occasional I get missfire codes on some cylinders, I replaced all coils and plugs, and it did not help with missfire, but car worked a bit more smooth.
So I tried with injector cleaner and it always helped for some extended period. I drive 95% of time on LPG, so my thought is that injectors get a bit dirty after some period, because car drives only few miles on gas, and that period is maybe too short to have them cleaned properly with only gas?
Try with some good injector cleaner first, it can't hurt Wink
And for the hissing noise in the pcv area, mine does that too, I also checked with break cleaner, and found nothing, but didn't tried with smoke machine yet. RR HSE 4.4 2006 LPG
Post #622944 8th Feb 2022 9:33am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
The hissing noise is normal. They breathe heavily from the PCV on the left bank to the throttle body. Coincidentally, also a common leakage point!
Mine misfires on cold idle. I was under the impression "they all do that sir"! Rolling with laughter 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #622948 8th Feb 2022 9:57am
dhallworth
Mine does it on petrol and LPG until it's warm so I'm ruling out an injector or an issue relating directly to one specific fuel.
I'm 98% sure my first 4.2SC didn't make any hissing noises from around the PCV and Sandy has said that his doesn't do it so I'm wondering if there's something amiss around the PCV.
It's definitely odd as my first one was as smooth as silk all of the time.
This one was always a bit lumpy at idle but it's got worse over the last week as the EML is now coming on when it's idling at cold. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #622954 8th Feb 2022 12:24pm
400-ascona
I've put two new LR PCVs on mine now and both do the same. I even bought a very expensive LR pipe to go from the PCV to throttle body. Still makes the noise. I also fitted a rubber hose so I could restrict the flow and it made no difference to how it ran.
Mines the same, it runs smooth when it's warmed up. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #622958 8th Feb 2022 1:00pm
dhallworth
Sounds like we've been through the same steps! Laughing
I replaced the PCV valve at around £30-40 and then spent over £100 for the pipe that runs from the PCV to the throttle body. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #622959 8th Feb 2022 1:04pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
David
Apologies checked mine yesterday and mines not making no air leak sounds either. Given that's two I'd say its a possibility there's a vacuum/air leak somewhere on your motor
Allen
Post #623042 9th Feb 2022 1:48pm
400-ascona
I've leak checked mine to death. No air leaks anywhere. Can still hear the air rushing through the PCV. And interestingly, if i pinch the pipe (I'm on a rubber hose at the moment), the noise stops or slows. 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #623046 9th Feb 2022 2:32pm
dhallworth
My old 4.2 definitely didn’t make the noise that this one makes so I’m convinced something is wrong.
Am hoping to give it a good look over at the weekend and am going to replace the cam cover gaskets too as there’s a weep on one.
Post #623100 9th Feb 2022 8:44pm
Sandyt
David I am at work at the moment but at home tomorrow morning I will video mine so you can hear for yourself if that helps
Post #623101 9th Feb 2022 8:46pm
dhallworth
Thanks Sandy. Smile
Hopefully I’ll find something that’s a nice easy fix and we can go on with getting some miles on it again!
Post #623103 9th Feb 2022 8:51pm
dingg1
Oddly I had multiple misfires and an eml light today, cleared the lot and all well since, weird as its been fine for the last 6 months Confused
Post #623116 9th Feb 2022 10:21pm
Page 3 of 4 <1234>
