Home > Technical (L322) > 2007 Supercharged Misfiring |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Check your connections at the pcv, its an inherent weakness in the design, I resorted to wrapping them in self amalgamating tape after lots of problems with air ingress |
7th Feb 2022 6:10pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
David,
7th Feb 2022 9:32pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
I don’t think so but that’s a good thought…
7th Feb 2022 10:20pm |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
Hi David,
8th Feb 2022 9:33am |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
The hissing noise is normal. They breathe heavily from the PCV on the left bank to the throttle body. Coincidentally, also a common leakage point!
8th Feb 2022 9:57am |
Mine does it on petrol and LPG until it's warm so I'm ruling out an injector or an issue relating directly to one specific fuel.
8th Feb 2022 12:24pm |
I've put two new LR PCVs on mine now and both do the same. I even bought a very expensive LR pipe to go from the PCV to throttle body. Still makes the noise. I also fitted a rubber hose so I could restrict the flow and it made no difference to how it ran.
8th Feb 2022 1:00pm |
Sounds like we've been through the same steps!
8th Feb 2022 1:04pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
David
9th Feb 2022 1:48pm |
I've leak checked mine to death. No air leaks anywhere. Can still hear the air rushing through the PCV. And interestingly, if i pinch the pipe (I'm on a rubber hose at the moment), the noise stops or slows. 05 L322 4.2SC
9th Feb 2022 2:32pm |
My old 4.2 definitely didn’t make the noise that this one makes so I’m convinced something is wrong.
9th Feb 2022 8:44pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
David I am at work at the moment but at home tomorrow morning I will video mine so you can hear for yourself if that helps |
9th Feb 2022 8:46pm |
Thanks Sandy.
9th Feb 2022 8:51pm |
Oddly I had multiple misfires and an eml light today, cleared the lot and all well since, weird as its been fine for the last 6 months |
9th Feb 2022 10:21pm |
