![]() | Home > Technical (L322) > Remotes do nothing |
batteries too low? need changing (my FBH remote battery was reading 2.88 but wouldn't work - Needs 3V. Changed battery and working again. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
Ok will i need to sync them after nee battery then ? |
Got new batteries in remotes but still nothing happening 😕 |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 173 ![]() ![]() ![]() |
Have you tried pulling the fuse for the FBH, refit and then try the sync procedure. |
No pal will try that now ,my fbh works which is helpful |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
All I can suggest, and I know folks seem to put it to a few things… is disconnect the car battery and do a hard reset….
Right, tried that , no change, i noticed that the light on my remote flashes 9nce i do the sync procedure, what does that mean ?? |
Some of the videos online are for the later touch screen cars, so not sure if you have seen those, but can’t imagine they will work as yours is the earlier BMW system.
I can only really see this one, looks like the process is the same from what I can see.
Yes pal , thats the one i followed, hard reset done , still nothing |
Think ive found the issue
That’s a start then… I was already out of ideas.
UPDATE , soureced a 2nd hand cassette , fitted , synced at the first try so all working again |
