Home > Technical (L322) > Remotes do nothing |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
batteries too low? need changing (my FBH remote battery was reading 2.88 but wouldn't work - Needs 3V. Changed battery and working again. |
29th Jan 2022 5:32pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Ok will i need to sync them after nee battery then ? |
29th Jan 2022 5:36pm |
Got new batteries in remotes but still nothing happening 😕 |
7th Feb 2022 12:39pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Have you tried pulling the fuse for the FBH, refit and then try the sync procedure. |
7th Feb 2022 2:17pm |
No pal will try that now ,my fbh works which is helpful |
7th Feb 2022 3:22pm |
All I can suggest, and I know folks seem to put it to a few things… is disconnect the car battery and do a hard reset….
7th Feb 2022 3:30pm |
Right, tried that , no change, i noticed that the light on my remote flashes 9nce i do the sync procedure, what does that mean ?? |
7th Feb 2022 3:50pm |
Some of the videos online are for the later touch screen cars, so not sure if you have seen those, but can’t imagine they will work as yours is the earlier BMW system.
7th Feb 2022 4:02pm |
I can only really see this one, looks like the process is the same from what I can see.
7th Feb 2022 4:10pm |
Yes pal , thats the one i followed, hard reset done , still nothing |
7th Feb 2022 5:03pm |
Think ive found the issue
7th Feb 2022 6:35pm |
That’s a start then… I was already out of ideas.
7th Feb 2022 7:43pm |
UPDATE , soureced a 2nd hand cassette , fitted , synced at the first try so all working again |
12th Feb 2022 1:43pm |
