Home > Technical (L322) > Remotes do nothing
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Remotes do nothing
Right , neither remotes do anything but both flash when buttons are pressed , ive tried the syncing methods ive found , all that happens is the red light on the remote flashes, what does this mean ? Any help much appreciated
Thanks
Post #621791 29th Jan 2022 2:43pm
Dolphinboy
batteries too low? need changing (my FBH remote battery was reading 2.88 but wouldn't work - Needs 3V. Changed battery and working again.
Post #621806 29th Jan 2022 5:32pm
bembo449
Ok will i need to sync them after nee battery then ?
Post #621810 29th Jan 2022 5:36pm
bembo449
Got new batteries in remotes but still nothing happening 😕
Post #622844 7th Feb 2022 12:39pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Have you tried pulling the fuse for the FBH, refit and then try the sync procedure.
Post #622856 7th Feb 2022 2:17pm
bembo449
No pal will try that now ,my fbh works which is helpful
Post #622863 7th Feb 2022 3:22pm
mjdronfield
All I can suggest, and I know folks seem to put it to a few things… is disconnect the car battery and do a hard reset….
I seem to remember that solved a similar issue on here recently.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #622865 7th Feb 2022 3:30pm
bembo449
Right, tried that , no change, i noticed that the light on my remote flashes 9nce i do the sync procedure, what does that mean ??
Post #622866 7th Feb 2022 3:50pm
mjdronfield
Some of the videos online are for the later touch screen cars, so not sure if you have seen those, but can’t imagine they will work as yours is the earlier BMW system.
Will see if I can see anything else…. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622869 7th Feb 2022 4:02pm
mjdronfield
I can only really see this one, looks like the process is the same from what I can see.
Seems you have to be patient and get it just right….
I imagine you’ve done this a few times.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622870 7th Feb 2022 4:10pm
bembo449
Yes pal , thats the one i followed, hard reset done , still nothing
Post #622878 7th Feb 2022 5:03pm
bembo449
Think ive found the issue
RF receiver is corroded inside
Post #622895 7th Feb 2022 6:35pm
mjdronfield
That’s a start then… I was already out of ideas.
Hopefully you will be sorted then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #622905 7th Feb 2022 7:43pm
bembo449
UPDATE , soureced a 2nd hand cassette , fitted , synced at the first try so all working again Very Happy
Post #623429 12th Feb 2022 1:43pm
