Home > Maintenance & Mods (L322) > A bit fell off.....
Jimmies
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Bournville
A bit fell off.....
I was happily bombing along in the L322 when all of a sudden I had a scraping followed by crunching noise and out the back saw one of the belly pans had come off, it looked like below...I'll take a look under her later but is this something you would say I should replace? I'm guessing the reason why it came off is either the connections are rusted through or it wasn't fitted tightly to start with
Post #622667 6th Feb 2022 9:11am
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Looks like the bolts were finger tight after an oil change? I would refit with new bolts and Penny washers. Torque it up to spec, and carry on regardless.
Post #622720 6th Feb 2022 1:46pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Keep it !
They're useful to help localise the oil stains on the drive Laughing Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #622725 6th Feb 2022 2:02pm
Jimmies
For clarity, my piece is actually in a few bits as it broke when it came off....I was just wondering if it is something I should be worried about replacing?
Post #622740 6th Feb 2022 3:49pm
DrRob
It protect to the engine sump and other bits from road debris flicking up etc
I’d replace it personally Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #622743 6th Feb 2022 3:52pm
Pawl
It has various functions that you can decide if you need or not - none critical - lol :
Reduces water / mud being sprayed around the engine / engine bay when you hit big puddles.
Absorbs minor oil leaks (if foam still on the topside)
Reduces spread of leaking oil by collecting it out of the airflow underneath
Minor reduction in engine noise transmission outside the car
Very minor improvement in aerodynamics / airflow under the car
Many owners are happy to live without any of the "benefits" to speed up oil changes / access underneath or just because it was taken off & lost by previous owners / "mechanics". Paul,
Post #622747 6th Feb 2022 3:59pm
Jimmies
Had a look underneath for the first time ( only had her a couple of week)...all looks pretty good under there from a rust perspective.
The mountings for this undertray look OK so it think it must have just been loose !!.....one thing I did notice though was more than a little bit of oil at the back part of the engine area .....not dripping but also not just a small amount.....I'm guessing this could be a sign of the oil cooler leaking. Any way to check short of taking off the bits in-between the Vee ?
I have a 4.4 tdv8 for reference.....I feel the start of some fun🤣
Post #622765 6th Feb 2022 6:18pm
Baltic Blue
Keep a close eye on the coolant expansion tank for signs of oil.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #622766 6th Feb 2022 6:32pm
Jimmies
Cheers Mike....I'll take a look tomorrow
Post #622770 6th Feb 2022 6:44pm
