![]() | Home > In Car Electronics (L322) > Is it me or is my Bluetooth faulty? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 599 ![]() ![]() ![]() |
Same symptoms I had, turned out to be a faulty Bluetooth module damaged by damp.
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
Thanks David.
I got mine from eBay, just checked and it was £50 including postage. If I remember right I did wait a while and just got lucky.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I have a Bluetooth module removed from a 2007 here if you need one - £40?
TJH - that would be perfect. Will you be ok to post it? I will PM my address and you can let me know the total amount and how to pay.
All fixed thanks to Tom.
Glad it sorted it for you |
I tried a repair on mine, once opened it was obvious of where the water had come from. It caused corrosion on the pins of the connector and then damaged the tracks on the circuit board to the first chip. I repaired these by soldering some fine wire on to the remains of good track.
