Home > Technical (L322) > Turbo going or ?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Turbo going or ?
06 td6 , been stood for 2 weeks , smokes once warm , im pretty sure its turbo but back when i had a disco 3 , this also smoked for the first few miles as it had been stood , its normal on them ,could it be the same on the td6 ???
Post #621425 25th Jan 2022 11:39pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Check your crank case filter LLJ500010 located in the rocker cover underneath the air filter, they can block causing crank case pressure and smoke. Try removing the oil filler cap with the engine running, if there’s a lot of back pressure its likely to be this small filter.
Post #621516 26th Jan 2022 10:47pm
mjdronfield
If it is the above filter, replace it with a later BMW vortex one. Never have to change it then….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #621519 26th Jan 2022 10:58pm
bembo449
Ok pal , will do that , ive seen / dealt with turbo failure before , the symptoms dont exactly fit in this case , i assume i have to remove the airfilter completely then ???
Post #621537 27th Jan 2022 8:12am
mjdronfield
I can’t remember mate, years since I had my TD6 and garage swapped mine. It’s not the air filter it’s the crankcase breather…. It tends to get missed when servicing and gets blocked. BMW changed it but had sold Land Rover by then.
I’ve a feeling it’s on the other side nearer the windscreen.
More info here…
https://www.fullfatrr.com/forum/topic9811....w+upgrades
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #621541 27th Jan 2022 9:45am
bembo449
Sorry pal , i misunderstood, you said , ok will have a look and update asap
Post #621546 27th Jan 2022 10:55am
bembo449
Post #621547 27th Jan 2022 11:11am
stuart_2006
See https://www.landyzone.co.uk/land-rover/l32...de.211041/ for a step-by-step.
Post #621597 27th Jan 2022 7:02pm
bembo449
Thanks pal , will check it out
Post #621674 28th Jan 2022 3:47pm
bembo449
Update ! Ive ordered a vortex breather but in the mean time i bodged it , just drive 40 miles and after a bit of smoke its no not smoking at all so fingers crossed, that was the issue
Post #621850 30th Jan 2022 9:39am
