Home > Technical (L322) > Turbo going or ? |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 453 |
Check your crank case filter LLJ500010 located in the rocker cover underneath the air filter, they can block causing crank case pressure and smoke. Try removing the oil filler cap with the engine running, if there’s a lot of back pressure its likely to be this small filter. |
26th Jan 2022 10:47pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7775 |
If it is the above filter, replace it with a later BMW vortex one. Never have to change it then….
26th Jan 2022 10:58pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
Ok pal , will do that , ive seen / dealt with turbo failure before , the symptoms dont exactly fit in this case , i assume i have to remove the airfilter completely then ??? |
27th Jan 2022 8:12am |
I can’t remember mate, years since I had my TD6 and garage swapped mine. It’s not the air filter it’s the crankcase breather…. It tends to get missed when servicing and gets blocked. BMW changed it but had sold Land Rover by then.
27th Jan 2022 9:45am |
Sorry pal , i misunderstood, you said , ok will have a look and update asap |
27th Jan 2022 10:55am |
27th Jan 2022 11:11am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 123 |
See https://www.landyzone.co.uk/land-rover/l32...de.211041/ for a step-by-step. |
27th Jan 2022 7:02pm |
Thanks pal , will check it out |
28th Jan 2022 3:47pm |
Update ! Ive ordered a vortex breather but in the mean time i bodged it , just drive 40 miles and after a bit of smoke its no not smoking at all so fingers crossed, that was the issue |
30th Jan 2022 9:39am |
