Home > Technical (L322) > (Solved) Urgent help needed - car is "dead"
jackie-o
Netherlands
Hi all and happy new year,
Once again drawing on the collective knowledge of the forum....
Drove the car on Friday, everything worked fine. On Sunday the car was completely dead. Car was fitted with new Varta Silver AGM in August. I replaced the battery in the key fob but no change...
Monday evening I hooked the car up to a ctek mx7 which showed the battery was completely flat. It charged for about 20 hours until it showed full.
In the meanwhile I used the key in the key fob to get in through the drivers door. Interior lights went on but nothing else. When trying to turn on the ignition it shows message "smart key not found".
Upon opening the drivers door a second time I activated the alarm which I managed to turnof by hitting the hazard button in the car. Sound off but all lights now blinking.
Full battery, according to ctek, did not improve anything. I then tried to disconnect the battery for a couple of minutes and hooked it up again - car acted exactly as earlier i.e alarm still on and only interior lights working.
Then tried to start it with cables from our second car but to no effect.
My indy says I have done pretty much what I can from home and it needs to be towed. His only concern is if it is a security issue then it needs to go to LR and not to him and they are literally on the other side of town...
Does anyone have any idea what this could be and can anyone suggest any possible fixes?
As always, very grateful for all advice!
//J RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #620453 18th Jan 2022 6:37pm
Weegie
When you did that did you touch the two ends of the battery cables together for a short time? John
GAP iiD BT
Post #620455 18th Jan 2022 6:46pm
jackie-o
Netherlands
No, Should I?
All i heard was my indy´s voice in my head to make sure not to short anything.... RR Vogue 4.4 TDV8 - 11
Post #620456 18th Jan 2022 6:48pm
Weegie
Give it a try. It is a way of resetting the electronics. You can't lose anything. Cables off the battery and the ends touched together. John
GAP iiD BT
Post #620458 18th Jan 2022 6:52pm
jackie-o
Netherlands
Thanks weegie!
So how long do they need to touch/connect, are we talking seconds or minutes? RR Vogue 4.4 TDV8 - 11
Post #620460 18th Jan 2022 6:54pm
Weegie
About 20 seconds or so. John
GAP iiD BT
Post #620461 18th Jan 2022 6:55pm
jackie-o
Netherlands
ok, will give it a try first thing in the morning!
On a related note; how can I access the rest of the car, most importantly the boot?
The central looking doesnt work... RR Vogue 4.4 TDV8 - 11
Post #620467 18th Jan 2022 7:18pm
mjdronfield
Gonna have to climb over and use the manual release facility……
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #620475 18th Jan 2022 7:36pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #620478 18th Jan 2022 7:38pm
jackie-o
Netherlands
Thanks both!
Tried Weegies suggestion but to no effect Sad
Could this be a safety/security issue?
Something has obviously drained the battery and made the car lose contact with the smart key.
Would I be able to read fault codes if i cant even get the ignition on?
//j RR Vogue 4.4 TDV8 - 11
Post #620539 19th Jan 2022 8:16am
mjdronfield
You might be able to use the smart key if you hold it against the dash… it’s normally for if the fob battery is flat… worth a try. It’s in the manual.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #620545 19th Jan 2022 9:22am
jackie-o
Netherlands
Thanks but already tried to no effect Confused RR Vogue 4.4 TDV8 - 11
Post #620547 19th Jan 2022 9:25am
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
I believe there is a procedure for changing the battery in the key fob to stop it de coding itself, i don't have any experience with your age RR but could that be the reason?
Post #620557 19th Jan 2022 10:08am
jackie-o
Netherlands
Thanks but according to manual it´s just a straight swap RR Vogue 4.4 TDV8 - 11
Post #620560 19th Jan 2022 10:31am
Graculus
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Can you now lock and unlock the vehicle using the remote key? If you can, lock and unlock it several times as this sometimes let's the car recognise the key again.
Try accessing the fuses behind the glovebox and removing fuse 17 (5amp, I think). Wait at least one minute and reinsert (check that the fuse is good!).
If that doesn't work, try another battery reset now that it's charged (disconnect, wait a couple of minutes and then reconnect).
If none of these work you may have an issue with the Keyless Vehicle Module. Other modules on the Canbus can also cause strange issues even if they may not be obvious. Have you had any water ingress or heavy condensation around any modules (boot area etc)?
Finally, is the battery definitely good? If it's been discharged for some time it may not have properly recovered. I'd connect.a good jumper pack or set your Ctek to Supply and try again.
Post #620565 19th Jan 2022 10:55am
