![]() | Home > Technical (L322) > (Solved) Urgent help needed - car is "dead" |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
When you did that did you touch the two ends of the battery cables together for a short time? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
No, Should I?
Give it a try. It is a way of resetting the electronics. You can't lose anything. Cables off the battery and the ends touched together. John
Thanks weegie!
About 20 seconds or so. John
ok, will give it a try first thing in the morning!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Gonna have to climb over and use the manual release facility……
Thanks both!
You might be able to use the smart key if you hold it against the dash… it’s normally for if the fob battery is flat… worth a try. It’s in the manual.
Thanks but already tried to no effect |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 224 ![]() ![]() ![]() |
I believe there is a procedure for changing the battery in the key fob to stop it de coding itself, i don't have any experience with your age RR but could that be the reason? |
Thanks but according to manual it´s just a straight swap RR Vogue 4.4 TDV8 - 11
Graculus Member Since: 18 Jan 2022 Location: Holywood Posts: 5 ![]() ![]() ![]() |
Can you now lock and unlock the vehicle using the remote key? If you can, lock and unlock it several times as this sometimes let's the car recognise the key again.
