![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 - Stage 1/Economy/Custom Re-map / TDI Tuning CRTD4 |
If the power delivery isn't smooth and instant and the economy is down maybe look at possible causes (Have you cleaned your MAP sensor ?) as I've got no complaints about mine in either of these areas. Also I've got an easy fix for disabling the 2nd turbo and saving fuel- just don't rev past 2.5k rpm! as max torque is already there at 1500rpm. If you do want a remap I doubt you will get more mpg unless it changes the laws of physics. These cars are pretty economical once moving but there is no way of getting 2.7t up to speed without using a lot of fuel. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Alive Tuning is the go to Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I was a sceptic until I used a DTUK box in direct comparison on the rolling road and in everyday driving. Then I got to know the company and the owner behind the company and the source of their products and distribution. Proper TüV certified products, and automotive looms. Great base maps, and they made me a specific one for my specific needs and car when towing the powerboat. It become so popular in the scene that it made it as a standard optional map.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
No issues with either apart from just wanting more. 2015 Range Rover Autobiography 4.4 SDV8 |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
They didn’t fit two turbos for fun, it’s a fairly involved system - just drive everywhere under 2400 rpm if you don’t want the smaller turbo spinning... |
The GAP IID tool will give you access to BAS tuning products which also include gearbox updates and other things that may improve your drivability - worth dropping them a line to discuss what you want. 2012 TDV8 Vogue (L322) |
rainking Member Since: 14 Jan 2019 Location: Buckingham Posts: 65 ![]() ![]() ![]() |
That's stout... my bone stock, full weight DSG 3-dr Mk7 R has a best 1/4 mile of 12.7 at Pod on a fully prep'd track. Andrew. |
Yes it was good. The thing went, all it had was the DTUK tuning box and pedal box, a bit so heavy driver and good launch control. TV was 119mph iirc. Amazingly stable tuning it was. My R was one of the first when it launched into the UK. It was a fun car but wore me out on longer journeys.
Do the tuning boxes work or do harm? I'm not talking about cheap ones, I'm talking about the DTUK and TDI Tuning ones which are c.£400 and come with their own looms.
Consensus is to avoid tuning boxes like a dose of clap. Remap only. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Tuning boxes definitely work. They work very well, and even receive TüV approval for use on roads.
Zerosumgame Member Since: 27 May 2021 Location: Petworth Posts: 45 ![]() ![]() |
I thought the consensus on mapping the 4.4 tdv8 was that the car is already running very near the torque limit of the gearbox and if you are looking for extra power use a JLR specialist like Alive or Bell Auto Services who will know this and accommodate |
They will only harm your wallet. If the ECU gets a whiff of anything being too far out of spec it will throw you a restricted performance warning and end your fun. Tuning boxes were great for old diesels where you could just over fuel and leave a cloud of black smoke behind you but once DPF's came in the parameters to fool the ecu into creating more power are limited. If you do go for a remap I'd strongly advise a specialist LR tuner as they will have the experience to know not just how to create power but also how to maintain DPF function. I'd expect a proper retune to also include changes to the gearbox programming as well for optimal drivability and economy. Even just a gearbox reprogram on it's own would likley help. 2012 TDV8 Vogue (L322) |
Depends on the box and the application. Had a DTUK box on an twin turbo car a while back and it was rubbish - fixed with a proper remap. Agree all remaps are not the same either and having done some DIY ECU remapping in the past and seen how little is changed on commercial off the shelf maps for so much charged it's ez money. 2012 TDV8 Vogue (L322) |
