Home > Maintenance & Mods (L322) > Dead Draper Oil Extractor - can it be revived?
Page 3 of 3 <123
suburbanspaceman
United Kingdom 2011 Range Rover Autobiography TDV8 Ipanema Sand
I just bought one of Amazon and mine is duff also! Not happy
Cheers
Post #609327 15th Oct 2021 10:10pm
suburbanspaceman
I had to buy a Clarke one locally. This one worked great but only 9Lt
Cheers
Post #609780 20th Oct 2021 10:31am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I've got a sealey one and it's been faultless. Doesn't look anywhere near as complicated as these ones! Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609784 20th Oct 2021 10:37am
JayGee
Mine’s just packed up after getting 8.5l out. No suction any more. Too messy to strip down so will return it to the seller. Utter junk…,, 2012 TDV8 Vogue (L322)
Post #620039 15th Jan 2022 1:26pm
Baltic Blue
For anyone having problems but out of guarantee period, you might want to check out my footpump mod earlier in this thread.
It’s very simple to modify and works well, similar principle to using a compressor rather than the built in hand pump.
I do agree though, they shouldn’t be failing , given that most will only be used a couple of times a year, whereas garages must use them every day.
Post #620042 15th Jan 2022 1:42pm
JayGee
Desperate to get out the oil I took the top off and pulled out the plunger and this seemed to reset something and it worked again. Possibly using it with the valve in the wrong setting or the red cap on the inlet caused a problem?
Looks to be pretty well made so will give it another chance....... 2012 TDV8 Vogue (L322)
Post #620048 15th Jan 2022 3:01pm
Ffrr-lover
Today I used my draper for the first time on my ff for its oil change. it’s been used a handful of times for draining my coolant and an oil change on a fiesta.
Today, however, it packed up and stopped sucking. As per JayGee, I popped the top off to have a look, wiggled a valve, and tried again and if made the right noises! So I put it back together and tried again… and happy it’s working as before!
My thinking is that this was the first time it sucked anything close to its limit. It’s possible that the cutoff valve closes but didn’t release properly… maybe due to the gloopy oil?
It may be sensible to empty it before it gets above 8(?) litres? Then do the rest?
And maybe giving the top a good thump would loosen the cutoff valve?
Just a few thoughts in case someone has the same issues… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #622475 4th Feb 2022 6:13pm
Page 3 of 3 <123
