Home > Maintenance & Mods (L322) > Dead Draper Oil Extractor - can it be revived?
Page 1 of 3 123>
GGDR
Got a used Draper Draper 77057 oil extractor pump off ebay...
This guy: https://www.machinemart.co.uk/p/draper-man...extractor/
Pumped for 15 mins and not a sausage. Baltic Blue Mike told me it only needs a few pumps and it's away. So this one's definitely had it. (I know you can hook up a compress or but I don't have one)
Whilst waiting for the seller to refund me, I'm interested to know if I can replace the seals.
Rang Draper but no seals or part are available, only a set of replacement add-on tubes
These things work like one of those garden sprayers I think.
 Cheers, Greg
Post #526315 28th Aug 2019 7:34am
DrRob
If its not being returned then strip it down and have a look over to see what's broken maybe?? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526316 28th Aug 2019 7:36am
mpirie
Maybe it uses commonly available O rings for seals?
Worth a look if you can.
Like Mike says, it only needs a couple of pumps to start sucking the oil out.
Mile
Post #526317 28th Aug 2019 8:08am
Baltic Blue
Is it possible to rig up a bit of plumbing to the air compressor connection and connect a tyre (footpump) schrader valve , to replace the built in pump ?.
Rolling with laughter It’s a bit early for my Heath Robinson brain.
Post #526318 28th Aug 2019 8:11am
Baltic Blue
Something like one of these ?
Mike.
https://rover.ebay.com/rover/0/0/0?mpre=ht...3248493674 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #526321 28th Aug 2019 8:31am
DrRob
Mike.
Not a bad idea. Connect a 12V air compressor Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #526330 28th Aug 2019 10:20am
Baltic Blue
It’s raining, so to satisfy my curiosity, I threw caution to the wind and ordered 2 for £3.19.
My thinking being, if it works I will stick the spare one in an envelope and send it to Greg, but only then realised they are coming from China with an expected delivery date at the end of September Embarassed , but the thought was there.
Post #526344 28th Aug 2019 1:05pm
Baltic Blue
Does anyone know the thread size on the compressor fitting valve ?
It is possible I will need one of these....
Getting expensive Rolling with laughter , nearly spent my pocket money.
Post #526345 28th Aug 2019 1:34pm
GGDR
Cheers for all the replies guys.
I'm reluctant to rig up an air compressor because for that I'd be better off buying a 12v oil extractor pump - making the Draper an over-complicated 10 litre bucket.
Thank you Mike for thinking of me. I always click on UK-only for any search.
I do like fixing things so once/if the seller leaves it with me I'll take it apart and start to look at the o-rings etc. I just don't know how these kind of pumps work. I guess it's an air pump to create the vacuum and somehow it doesn't pump oil, just the air. Will get my head around it....
. Cheers, Greg
Post #526354 28th Aug 2019 3:17pm
Baltic Blue
I remember repairing my bicycle pump when I was about 10 by oiling the leather washer Rolling with laughter Rolling with laughter
Post #526358 28th Aug 2019 4:05pm
GGDR
Could be an easy fix:
 Cheers, Greg
Post #526382 28th Aug 2019 7:17pm
GGDR
Ok so I opened it up.
Having thought it over I realised the principle difference is that garden sprayers fill with pressure, and this one is the opposite, the air is removed.
But the above youtube link is where I started, the main plunger.. The rubber seems ok.
It doesn't 'look' the best visually but it's a lot wider than the cylinder. I actually turned it over to increase the outward pressure just in case. (maybe I'm wrong)
I'm not sure how the plunger creates suction exactly. I guess it's all about the valve which should eject the air - I think it's this one
This valve makes a high whoosh sound as I pump. When I squeeze the black thin top-to-bottom hose under the valve , the whoosh stops. Either have no effect on suction (in my case no suction.).
Still trying to figure it all out.... Cheers, Greg
Post #526644 31st Aug 2019 11:56am
GGDR
ok just discovered there is a one-way 'air out' valve at the bottom of the cylinder:
Well you can't really see it but this looks down inside the cylinder. There is a lot of oil in there, I have a theory that oil should not enter this area and may have degraded the seals.
Still going....
. Cheers, Greg
Post #526651 31st Aug 2019 12:33pm
Baltic Blue
Morning Greg,
I love your never say die spirit....
You will get it working come what may.. Bow down
Are you getting your money back, or not?
I assume you have tried testing it by actually putting the end of the suction tube in a bucket of water or similar ?
How do you get the pump apart,? Does the handle come off ?
Post #526653 31st Aug 2019 12:39pm
GGDR
Cheers Mike.
The whole top comes off with eight screws.
I'm not sure if I can sort it actually, I can't identify the problem so far...
It's funny you said previously about fixing your bike pump with leather, this is the plunger seal. Looks like leather to me....
 Cheers, Greg
Post #526658 31st Aug 2019 2:06pm
Page 1 of 3 123>
