Home > Technical (L322) > Squeaky wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
pads surface needs copaslip applied.. ... - .- -.
27th Apr 2011 4:12pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1511 |
+1 copper grease.
27th Apr 2011 5:02pm |
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 |
So wheel off, remove callipers, bit of anti-squeal paste on the back and chuck it all back together? |
27th Apr 2011 5:16pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Another tip is to lightly chamffer the edge of the pads |
Sorry about the spelling - think my keyboards turned dyslexic |
27th Apr 2011 5:17pm |
... - .- -. Y. O. L. O. . |
27th Apr 2011 5:21pm |
On the Brembos you shouldn't have to remove the calliper, just use a 3/16" punch to drift the pins out and you should be able to wrangle the pads out the back of the calliper.
27th Apr 2011 6:24pm |
Thanks for the help gents.
27th Apr 2011 7:19pm |
28th Apr 2011 4:52pm |
Try my suggestion All brakes squeal to some extent - the copper slip etc just takes it to a different frequency so we can't hear it . |
28th Apr 2011 4:54pm |
you could take it back to whoever done the job and ask them to sort it.... ... - .- -.
28th Apr 2011 4:55pm |
It's not the brakes that are squealing when in use, although it seems to start after the brakes have been used if that makes sense. |
28th Apr 2011 5:15pm |
Looks like the best option. It's just a pain in the rear as they are quite a long way from us. |
It couldn't be a poorly adjusted e brake could it? Did he do the rears?
28th Apr 2011 6:33pm |
