Home > Technical (L322) > Squeaky wheel
rocksteadyeddie
Squeaky wheel
I recently had the pads and discs done on the front of my FFRRSC.
Since then the drivers side wheel squeaks periodically. When it does so the squeak is "solved" by applying the brakes - even quite gently. My immediate thought was either wheel bearing or rubbing pad (although I am not quite clear why this would squeak). Any ideas chaps?
p.s. I have a sound file but have no idea how to post it.
Post #61711 27th Apr 2011 4:07pm
pads surface needs copaslip applied.. ... - .- -.
Post #61712 27th Apr 2011 4:12pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 copper grease.
Also heard that if the springs holding the pads aren't right it can destabilise and cause a squeak.
IIRC. You can drift out the pins to get at the pads without much stress. Thumbs Up
Post #61720 27th Apr 2011 5:02pm
rocksteadyeddie
So wheel off, remove callipers, bit of anti-squeal paste on the back and chuck it all back together?
Post #61722 27th Apr 2011 5:16pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Another tip is to lightly chamffer the edge of the pads Smile
Post #61723 27th Apr 2011 5:16pm
mercs600
Sorry about the spelling - think my keyboards turned dyslexic Embarassed
Post #61724 27th Apr 2011 5:17pm
Thumbs Up ... - .- -.
Post #61725 27th Apr 2011 5:21pm
Stephen.125
On the Brembos you shouldn't have to remove the calliper, just use a 3/16" punch to drift the pins out and you should be able to wrangle the pads out the back of the calliper.
Once you get the wheel off all will be revealed.
Post #61728 27th Apr 2011 6:24pm
rocksteadyeddie
Thanks for the help gents.
I just drifted the pins out. It "appeared" that there was already copper clip on the back of pads. Didn't know how much to put on so just smeared plenty around. Test drive revealed a solitary speak after coming to a stop and then setting off again. I am hoping that this was just them bedding in, and that the problem is solved.
Fingers crossed.
Post #61733 27th Apr 2011 7:19pm
rocksteadyeddie
Big Cry
Seemed to be fine. Then it returned. For no good reason.
It comes and goes but is very annoying.
Any other ideas?
Post #61916 28th Apr 2011 4:52pm
mercs600
Try my suggestion Smile All brakes squeal to some extent - the copper slip etc just takes it to a different frequency so we can't hear it .
Post #61917 28th Apr 2011 4:54pm
you could take it back to whoever done the job and ask them to sort it.... ... - .- -.
Post #61919 28th Apr 2011 4:55pm
rocksteadyeddie
It's not the brakes that are squealing when in use, although it seems to start after the brakes have been used if that makes sense.
Post #61928 28th Apr 2011 5:15pm
rocksteadyeddie
Looks like the best option. It's just a pain in the rear as they are quite a long way from us.
Post #61929 28th Apr 2011 5:15pm
Stephen.125
It couldn't be a poorly adjusted e brake could it? Did he do the rears?
Can you trundle around slowly whilest someone listens to isolate it?
Are they genuine parts? It couldn't be just that the pads need to build up a decent friction 'coal' could it?
Sorry for more questions- just intrigued! Thumbs Up
Sorry just re-read original post- clearly overdone it on the moron pills today!
I'll have a rethink!
Post #61954 28th Apr 2011 6:33pm
