![]() | Home > Technical (L322) > Squeaky wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
pads surface needs copaslip applied.. ... - .- -.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
+1 copper grease.
rocksteadyeddie Member Since: 15 Jan 2010 Location: London Posts: 38 ![]() |
So wheel off, remove callipers, bit of anti-squeal paste on the back and chuck it all back together? |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Another tip is to lightly chamffer the edge of the pads |
Sorry about the spelling - think my keyboards turned dyslexic |
![]() Y. O. L. O. . |
On the Brembos you shouldn't have to remove the calliper, just use a 3/16" punch to drift the pins out and you should be able to wrangle the pads out the back of the calliper.
Thanks for the help gents.
Try my suggestion |
you could take it back to whoever done the job and ask them to sort it.... ... - .- -.
It's not the brakes that are squealing when in use, although it seems to start after the brakes have been used if that makes sense. |
Looks like the best option. It's just a pain in the rear as they are quite a long way from us. |
It couldn't be a poorly adjusted e brake could it? Did he do the rears?
