Home > My Range Rover > Cam Tech Craig's New SV LWB
Page 6 of 14 <123 ... 567 ... 121314>
Let the fun commence Thumbs Up
Post #619066 7th Jan 2022 12:14am
dhallworth
Can't wait to see this finished Very Happy 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #619069 7th Jan 2022 1:11am
Thank you David… Will take a little while for the Bodyshop to paint the bits but at least that gives me time to strip and refinish things like the brakes… 👍
Post #619085 7th Jan 2022 8:55am
Are the new style headlights a straight swap Craig? Got - 2017 SDV8 Autobiography in Loire Blue
Post #619089 7th Jan 2022 9:38am
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Will be great to watch your build Thumbs Up did you go for the Laser pixel headlights ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #619090 7th Jan 2022 9:39am
Martin2
I can't believe this job is a higher priority than fixing the buckled garage door! Rolling with laughter MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #619094 7th Jan 2022 9:54am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Watching with interest.
Sure it'll look great when done. What do I put here then?
Post #619098 7th Jan 2022 10:19am
That only happened about hmmmmmm 🤔 three years ago? 🤭😏🙄
Post #619102 7th Jan 2022 10:48am
No sir… You have to replace the LCM with a purpose built unit sir… 👍
Post #619103 7th Jan 2022 10:49am
MJGH
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Do you also need to replace the bonnet & grill to accommodate the new style light?
Post #619155 7th Jan 2022 9:38pm
Cosmetically You need to change the headlights, grille, bumper & bonnet...
Rear will be rear lights & rear bumper...
Not forgetting everything you don't see behind the outer skin... Whistle Thumbs Up
Post #619158 7th Jan 2022 10:29pm
dhallworth
I’ve wondered about a 2012 facelift on my 2007 car but it’s all of the bits behind the scenes that puts me off doing that one. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #619161 7th Jan 2022 10:36pm
The brakes on my car have never felt as good as I think they should have. So, today I stripped them so I could visually inspect them and see if there were any issues with the braking components...
I was shocked to see the rear caliper carrier bolt loose! Shocked
I removed the brake pads to find they are the ECP specials i had warned the forum about... Bloody brilliant! Needs new pads all the way around!
I have removed the discs now so that I can paint the bells and the outer cooling vanes so they don't rust and look YUK in five minutes...
More to follow as I progress... Thumbs Up
Post #619244 8th Jan 2022 10:54pm
dhallworth
On an approved used car that caliper bolt is very disappointing!
I don’t understand why someone would have a car like that and fit cheap brakes to it either!
It’ll be fantastic once you’ve worked your magic on it!
Post #619247 8th Jan 2022 11:13pm
David, i don't think the Brembo brakes are that cheap to buy albeit they are the cheapest composition hence feeling "crap" to press... Rolling Eyes
Post #619256 9th Jan 2022 12:21am
