![]() | Home > My Range Rover > Cam Tech Craig's New SV LWB |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Let the fun commence
Thank you David… Will take a little while for the Bodyshop to paint the bits but at least that gives me time to strip and refinish things like the brakes… 👍 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Are the new style headlights a straight swap Craig? Got - 2017 SDV8 Autobiography in Loire Blue
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 744 ![]() ![]() ![]() |
Will be great to watch your build |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 800 ![]() ![]() |
I can't believe this job is a higher priority than fixing the buckled garage door! |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Watching with interest.
That only happened about hmmmmmm 🤔 three years ago? 🤭😏🙄 |
No sir… You have to replace the LCM with a purpose built unit sir… 👍 |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
Do you also need to replace the bonnet & grill to accommodate the new style light? |
Cosmetically You need to change the headlights, grille, bumper & bonnet...
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
I’ve wondered about a 2012 facelift on my 2007 car but it’s all of the bits behind the scenes that puts me off doing that one. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
The brakes on my car have never felt as good as I think they should have. So, today I stripped them so I could visually inspect them and see if there were any issues with the braking components...
I removed the brake pads to find they are the ECP specials i had warned the forum about... Bloody brilliant! Needs new pads all the way around!
I have removed the discs now so that I can paint the bells and the outer cooling vanes so they don't rust and look YUK in five minutes... More to follow as I progress... ![]() |
On an approved used car that caliper bolt is very disappointing!
David, i don't think the Brembo brakes are that cheap to buy albeit they are the cheapest composition hence feeling "crap" to press... |
