Home > My Range Rover > Cam Tech Craig's New SV LWB |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Let the fun commence
7th Jan 2022 12:14am |
Thank you David… Will take a little while for the Bodyshop to paint the bits but at least that gives me time to strip and refinish things like the brakes… 👍 |
7th Jan 2022 8:55am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 |
Are the new style headlights a straight swap Craig? Got - 2017 SDV8 Autobiography in Loire Blue
7th Jan 2022 9:38am |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 |
Will be great to watch your build did you go for the Laser pixel headlights ? 2021 P400 Silicon Silver AB
7th Jan 2022 9:39am |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 784 |
I can't believe this job is a higher priority than fixing the buckled garage door! MY23 Panamera E-Hybrid
7th Jan 2022 9:54am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Watching with interest.
7th Jan 2022 10:19am |
That only happened about hmmmmmm 🤔 three years ago? 🤭😏🙄 |
7th Jan 2022 10:48am |
No sir… You have to replace the LCM with a purpose built unit sir… 👍 |
7th Jan 2022 10:49am |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 |
Do you also need to replace the bonnet & grill to accommodate the new style light? |
7th Jan 2022 9:38pm |
Cosmetically You need to change the headlights, grille, bumper & bonnet...
7th Jan 2022 10:29pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 |
I’ve wondered about a 2012 facelift on my 2007 car but it’s all of the bits behind the scenes that puts me off doing that one. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
7th Jan 2022 10:36pm |
The brakes on my car have never felt as good as I think they should have. So, today I stripped them so I could visually inspect them and see if there were any issues with the braking components...
8th Jan 2022 10:54pm |
On an approved used car that caliper bolt is very disappointing!
8th Jan 2022 11:13pm |
David, i don't think the Brembo brakes are that cheap to buy albeit they are the cheapest composition hence feeling "crap" to press... |
9th Jan 2022 12:21am |
