![]() | Home > In Car Electronics (L405) > CarPlay |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2052 ![]() ![]() |
That's why I bought one from Charles at RR world. More expensive, yes, but he fitted it, made sure it was all up and running and is always about if you need help. |
To be honest Craig I don't know.
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
Can’t recall whether this has been asked before, but has anyone thought through or checked whether these types of adaptation are enough to mean that insurers should be notified? 2016 SDV8 AB |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Ok, easy way to check… What does your dashboard display whilst you listen to Spotify or your phone? Bluetooth or Auxiliary Selected? |
Yes, your insurance company should be informed no matter how small the modification! And the kicker is, most will note it on the file and say thank you with no cost… 👍 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
@Craig, i think nbunny has the £1k android replacement unit and not the £500 add-on... ... - .- -.
Yes he does Stan, I'm trying to understand whether it links the music through Bluetooth or a cable into the Auxilary socket |
ah ok..is this the full size android one you are 'testing'? ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Are their any advantage/ disadvantages to using Apple CarPlay or Android ??
as far as i can see they are equally comparable ..maybe the carplay has the slight edge on icon display ...
No Stan, I had the full size in my last 405 and found I used it more on the original RR screen as wifey uses the massage system constantly... (massage needs re-initiating every 5 or 10mins) I have the carplay add on in my latest car and this one allows the seat menu to overlap the carplay screen so, an immediate upgrade over the android full sized screen... ![]() |
@Mike, try the sound via the FM, you'll be surprised at the quality.
