Home > Maintenance & Mods (L322) > 4.4 TDV8 Torque settings and where’s the thermostat |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Have a look in the WM in the Wiki. May take a search around to find all you need, but reckon most would be in there, most likely in the removal/refitting sections for parts.
16th Dec 2021 9:25am |
Mjak42 Member Since: 11 Mar 2021 Location: Warragul, Victoria Posts: 15 |
Thanks Richard, yes I’ve had a look at the WM 4000 pages I think and all I seem to find is the 3.6 and 5.0, be great if there was an index or something, cheers Mike |
16th Dec 2021 9:33am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2494 |
Here's the thermostat...
16th Dec 2021 9:55am |
Thanks Graeme, I’m just looking through the WM up to page 649 so far 😂 parts better turn up tomorrow otherwise I may as well have ordered them from the UK |
16th Dec 2021 10:01am |
I'm using the 2010-2012 manual, not the one which includes the 3.6/4.4/5.0 engines. It's the top of the 3 for the 2010/2012 models
16th Dec 2021 10:02am |
Was wondering if I was looking at the wrong one, but it does say 4.4 😂 I’ll get off my iPad and do it on the computer, thanks for the tip |
16th Dec 2021 10:05am |
Let us know how you get on Cheers
16th Dec 2021 10:14am |
All done and saved on my computer, the more I work on the car the less afraid I am of it and this WM will be a great help, thanks for your help Richard and Graeme who I seem to always count on to answer one of my Questions, cheers will update this when I reassemble with the new parts. |
16th Dec 2021 10:39am |
Pleased to help.
16th Dec 2021 11:49am |
Just reading through about the crankshaft seal, gee Landrover like their special tools 😂 they say don’t reuse the crank bolt, my mechanic who works on my car, but is flat out till Xmas then closed to beginning of Feb, and we’re going away in the caravan after new year, he never mentioned that and torque on that bolt is 600nm might have to borrow or see if I can hire a bigger Torque wrench, will have to see what size pipe I’ve got at home and make some of my own tools, like the fan pulley bolt holder to get fan off, took me thirty minutes I now have a tool that would have cost me around $280aud.
16th Dec 2021 11:57am |
I haven't seen the instructions for tightening the 4.4's crankshaft bolt but if it's similar to the 3.0 TDV6 then the bolt is a stretch bolt, tightened to a torque which is it's yield point then turned more, so should not be re-used. |
16th Dec 2021 7:44pm |
Not having much luck, parts should arrive tomorrow, finished my jobs early today so thought I’d get the thermostat housing and water pump off so I’m ready to fit new parts, took thermostat housing off and everything came out with the help of the spring, found a little bit of plastic in there, realised when looking at WM picture there should be two little tabs that hold the thermostat in place, NO there gone, when I took the little hose clip out and removed hose found out part of the clip retainer was missing, ordered parts, unfortunately you have to buy the entire housing part # LR110459 not just the part that I want, it’s part number is NSS (not supplied separately) 😂 should be here Wednesday
20th Dec 2021 5:41am |
