Home > Maintenance & Mods (L322) > Suspension fault
C11ONX
Suspension fault
Hi all
I have the following suspension fault on my 2011 4.4 TDV8.
C1A13, I believe it’s the brass valve, that needs removing and drilling out/cleaning.
Has anyone done this and do you have any tips or is it as straightforward as I am led to believe?
Cheers 2011 TDV8 | overfinch genuine build | mapped
Post #615918 11th Dec 2021 11:52pm
rjff
There are quite a few threads on this around on here and if you look in the WM in the Wiki under suspension fault codes you'll see the code identfied and suggested possible causes.
Can we assume your suspension is taking a longer time to lower?
The brass valve is, I suppose, the exhaust silencer and it is known to beome resrticted in some cases. The suggested remedy to check by removing and test the suspension and then bore a 2mm hole straight through until you decide to replace it, if it's available as a spare.
Others may be along with more knowledge, but HTH. Cheers
Richard
(there are no such things as an ordinary FullFat, an ordinary cat or too many tools)
2011 TDV8 Vogue Santorini Black
Gap IIDBT
Post #616045 12th Dec 2021 9:22pm
bishbosh10
Very easy to drill through the exhaust silencer. Do it off the vehicle and make sure all the swarf is blown out before refitting. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #616141 13th Dec 2021 2:41pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
noted RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #616143 13th Dec 2021 2:53pm
knares
is this the exhaust silencer.
thanks RR 2005 4.4 petrol
Post #616593 16th Dec 2021 11:12am
knares
ok i found the breather, looks like new, so dose the commpressor, i havent removed it, dont know if i should RR 2005 4.4 petrol
Post #616610 16th Dec 2021 12:46pm
rjff
Hi Knares
I'm not familiar with the 2005 model, so can't tell you whaqt the photo is of.
Don't want to hijack the thread, but I'm not sure why you are looking at the compressor? Have I missed antoher threasd of yours? Cheers
Richard
Gap IIDBT
Post #616618 16th Dec 2021 12:58pm
@ Knares, if i remember correctly that is the PRV - pressure relief valve.
If you have a brass exhaust valve on your 2005, it will be on the compressor itself. .
Post #616648 16th Dec 2021 4:53pm
knares
rjff no you didn’t miss any thing, after reading C11ONX post it got me thinking about mine
i will make another post
joe90, yes, i found it thanks RR 2005 4.4 petrol
Post #616950 20th Dec 2021 12:41am
