Home > Technical (L322) > RR problems no drive |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
What year is it Clive? It’s the BMW 4.4, which can have gearbox issues, if it’s knackered then there a few recommendations for places which will refurb or replace transmissions (from memory Bristol transmissions were recommended by another member).
8th Dec 2021 3:59pm |
Out of interest have you checked transmission fluid levels? And is there any record of the gearbox being serviced? |
8th Dec 2021 4:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7803 |
4x4 light? It’s permanent 4 wheel drive… I take it you mean the low range light, the one that looks like mountains?
8th Dec 2021 4:46pm |
Clive F Member Since: 08 Dec 2021 Location: B69 1SU Posts: 5 |
It was first registered in September 2002 and I believe it's the 4.4 BMW engine. I haven't checked the gearbox oil level yet and I'm not fit enough to go crawling around underneath car's anymore. I'll see if I can get someone to have a look for me but if that turns out to be ok then I'll just get rid of it, I only gave scrap money for it anyway. Do you think that could be the reason it won't come out of 4x4 mode. Regards Clive |
8th Dec 2021 6:55pm |
It’s always 4x4. It’s impossible to make it anything else. I think it’s stuck half in Low range….. unless that’s what it does as a symptom of the gearbox being dead.
8th Dec 2021 7:23pm |
The car never came with any service records so haven't really got a clue and I can't get any information from the previous owner as he's had a stroke and can't speak very well and yes your right it's the light that looks like a mountain and it's stuck on permanently. Any help would be most appreciated. Kind regards Clive |
8th Dec 2021 7:27pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
car running..put car in neutral, foot on brake, and pull the left switch on the console, with mountain symbol, it should go back to high range. if not, it might be a stuck transfer box stepper motor. not hard to change. if you bring up the revs, does it sound like the gearbox is spinning up and dropping through the gears? as you say it crunches when put into park... sounds like something is spinning. there is also a fuse you insert to make car sit in neutral (ie no drive) for towing it short distances... it might have been recovered and 'recovery fuse' still fitted.
8th Dec 2021 8:39pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
Certainly worth trying some Fuse 37 action
9th Dec 2021 12:53am |
Thanks for your advice, I'll get my son-in-law to have a look for me, I think you could be right about the fuse as the car must have been towed but I can't ask the guy I purchased the car from as he's had a stroke and has lost his speech, will let you know how I get on.
10th Dec 2021 9:32am |
A big big thanks to all that have given me advice on my old L322 problem, you were right about fuse number 37 car now engages gear's and low range light has now gone off.
12th Dec 2021 3:15pm |
I think there maybe separate threads on both of these topics. If you use the search function it should bring them up.
13th Dec 2021 10:03am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
When I bought my RR (the same as yours) the suspension was on the rocks.
13th Dec 2021 2:07pm |
