Home > Maintenance & Mods (L405) > L405 Park brake fault (Yellow light)
Page 2 of 3 <123>
Te He... Laughing That'll be a Range Rover sir Thumbs Up
Post #580514 19th Jan 2021 11:59pm
TJH1985
No fault on ours, but the MD did replace one under warranty at the last service for hairline cracks in the case which they said often leads to water ingress and then total failure including the calliper Shocked Not sure if that was just MD scaremongering though. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #580526 20th Jan 2021 9:56am
Edgey808
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Handbrake failure.....
Well I’ve had the first failure.....RHS motor has failed and I can’t move the beast..... Sad
RAC have confirmed this and plan to recover the Beast on Monday onto a big yellow taxi Big Cry
I have to admit it’s the first time I’ve been recovered on a big yellow taxi......
The RAC guy did mention the housing is cracked, and this allows the elements inside .....?
I’ll see more from my Indy next week....
Fingers crossed Warranty wise play ball with my claim....?
Stephen.
Post #580903 24th Jan 2021 12:11am
TJH1985
Sounds like a design flaw... I did think it was an odd thing for the main dealer to inspect so closely, they must see them allot! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #580947 24th Jan 2021 2:53pm
Edgey808
Photos of the cracked motor cases.
Post #580950 24th Jan 2021 3:39pm
Edgey808
Removed the failed motor 😡
Other side is probably in the same state, but hasn’t failed yet. (Both side now being replaced.)👍
Post #581121 25th Jan 2021 6:48pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Great pics
Will help mine is intermittent at the mo so saving for a dry day.
Going to code read tonight and work out which corner! Help got CAR OWNER VIRUS!
Post #581640 29th Jan 2021 5:10pm
wealy
Does the code read tell you which side?
Post #613014 18th Nov 2021 10:11am
wealy
bump
Post #613185 19th Nov 2021 7:46pm
wealy
Post #614853 5th Dec 2021 3:40pm
wealy
look at those cracks!
Post #614854 5th Dec 2021 3:41pm
albertocsoares
2013 Range Rover Vogue SDV8 Siberian Silver
Thank you. I probably have the same problem as when I drive under heavy rain the hand brake light goes on.
Post #618010 30th Dec 2021 12:03pm
PhillV8s
United Kingdom 2013 Range Rover Vogue SE SDV8 Aintree Green
I had a few incidents of the parking brake refusing to lock or unlock when wet. Just fitted a new actuator today. Found a replacement on ebay for £74 (new part) which upon arriving looks identical to the the OEM item, just without dealer tax. Fitted and working fine. Will swap the other side over when it’s a little warmer as a precautionary measure.
Managed to do it with just the car in off road height and rolling around on my back but would be easier to take wheel off next time around for easier access. 2013 SDV8 4.4 Vogue SE Aintree
Post #658464 4th Mar 2023 7:02pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Do these actuators need coding or are they plug and play? 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #658494 5th Mar 2023 9:29am
PhillV8s
They don’t need coding. Just make sure the cable plug is fully seated when fitting the new unit. There is a small cable that clips in under the plug socket housing which can prevent the plug being fitted correctly. Ask me how I know!
It would be wise to seat the plug first then then tuck the smaller cable in place. 2013 SDV8 4.4 Vogue SE Aintree
Post #658495 5th Mar 2023 9:40am
Page 2 of 3 <123>
