Home > Maintenance & Mods (L405) > L405 Park brake fault (Yellow light) |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Te He... That'll be a Range Rover sir |
19th Jan 2021 10:59pm |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 |
Well I’ve had the first failure.....RHS motor has failed and I can’t move the beast.....
23rd Jan 2021 11:11pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Sounds like a design flaw... I did think it was an odd thing for the main dealer to inspect so closely, they must see them allot! Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
24th Jan 2021 1:53pm |
24th Jan 2021 2:39pm |
25th Jan 2021 5:48pm |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 |
Great pics
29th Jan 2021 4:10pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Does the code read tell you which side? |
18th Nov 2021 9:11am |
bump |
19th Nov 2021 6:46pm |
5th Dec 2021 2:40pm |
look at those cracks! |
5th Dec 2021 2:41pm |
albertocsoares Member Since: 28 Nov 2012 Location: Brazil Posts: 15 |
Thank you. I probably have the same problem as when I drive under heavy rain the hand brake light goes on. |
30th Dec 2021 11:03am |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 43 |
I had a few incidents of the parking brake refusing to lock or unlock when wet. Just fitted a new actuator today. Found a replacement on ebay for £74 (new part) which upon arriving looks identical to the the OEM item, just without dealer tax. Fitted and working fine. Will swap the other side over when it’s a little warmer as a precautionary measure.
4th Mar 2023 6:02pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1190 |
Do these actuators need coding or are they plug and play? 2017 SDV8 4.4 silicon silver AB
5th Mar 2023 8:29am |
They don’t need coding. Just make sure the cable plug is fully seated when fitting the new unit. There is a small cable that clips in under the plug socket housing which can prevent the plug being fitted correctly. Ask me how I know!
5th Mar 2023 8:40am |
