Home > Maintenance & Mods (L322) > Accessing the rear wiper motor/blade on a 2010 on FFRR
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
All having done this a few times and the fact that there are many posts about the rear wash/wipe I thought I’d do a quick write up of how to access it.....with pics
You do have to remove the spoiler - I did mine this evening and literally took 5 minutes.
First you have to remove the trim panel from the inside. Grab the top of the panel and pull away from the glass and then downwards. It can be quite stiff to start with if it’s not been off before - be bold...!
You should then see 3 silver bolt heads at the top (circled in red) - although the bottom edge now you have the tailgate up - these secure the spoiler to the car. (10mm)
Undo and remove them. Now, assuming you are standing behind the car, pull the spoiler towards you (pulling it towards the back of the car) as there are two white locating rings on the tailgate.
Once you have pulled the spoiler about 2 inches or so backwards it just ilfts up and off - Its attached by a cable which I guess i the high level stop light - I placed a couple of cloths on the roof and laid it back down as the wire is long enough to allow this without removing it.
Now you can get to the black plastic wiper arm cover - be a little careful as the plastic is likely to be a bit brittle. (ask me how I know)..! But I doubt they are expensive to replace. - edit - not available separately and £47 including new wiper arm..!
Pull the larger end away from the window and when it starts to move, start to lever it towards the left as the rest of the cover sits under the wiper arm.
Once out, you will see the 2 tiny holes/jets - I used my air compressor to blow through but a very small pin will probably do the trick.
Fit in reverse - it litterally can be done in under 15 minutes
Once it’s back together you can adjust the jets as you can the front ones - a small pin inserted in the hole and you can angle the jet as required.
HTH Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #579203 10th Jan 2021 6:02pm
DrRob
Bow down
Love these write ups Thumbs Up
Wiki it Stan Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #579205 10th Jan 2021 6:13pm
done Thumbs Up ... - .- -.
Post #579211 10th Jan 2021 6:33pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
Beware that putting the spoiler back can be a pain.
I wish I had just given the jets a good poke with a safety pin first as there wasn’t that much gunk blocking mine. I’d suggest trying that first before taking it apart... 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #592926 2nd May 2021 5:26am
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
If you're just changing the blade, you can have someone open the tailgate as the wiper is mid swipe and it will stop. This is the manufacturer suggested process
Post #614215 30th Nov 2021 12:25am
comports
Correct chdavis
This is relly only required if you specifically need to get to the wiper motor to investigte/rectify leaks in the pipe (quite common for the flexu hoses to come lose) or to clear the jets.
Although clearing the jets can be done with an airline from the outside without this removal, its also quite common to blow the pipes off like this (so you could end up removing it anyway)
If you simply want to change the blade and you have a push button start, just turn the wiper on and go stand behind the car - lift the tailgate (i.e. pull the catch to open) when the wiper arm is near the 6 o'clock position. you don't necessarily need 2 people to do it
HTH Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #614222 30th Nov 2021 6:54am
TDV8 Paul
And if you have key start, turn ignition on (not engine) operate rear wiper then turn off ignition and remove key when wiper is in the position you want. Easy change 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #614362 1st Dec 2021 11:49am
bishbosh10
You don't have to get out of the car - the tailgate release button on the dash will pause the wiper when you press it. Smile Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #614371 1st Dec 2021 12:49pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Rear wiper change
That's a great way BishBosh 10 next time i need to change it!!! Rolling with laughter
cheers Dave
Post #614393 1st Dec 2021 3:46pm
supershuttle
Before Stan reminds people, remember to put all the bolts back before driving up the motorway Whistle Net result repair done for next to nothing new spoiler painted with new brake light - say a couple of hundred quid but it was funny Rolling with laughter Geoff
Post #614395 1st Dec 2021 3:59pm
damn, you beat me to it ... Laughing ... - .- -.
Post #614396 1st Dec 2021 4:01pm
